I think but I keep the steamvr SS on 100% so it doesn’t affect it (think what I said about changing SS on openvr specifically makes no difference lol)
quietly hopes this is an issue with the program and not anything in unreal engine. XD
Im very curious what games besides The Lab you can run on super sampling 3 or higher with your 1080Ti, as my 1080Ti @2.1Ghz, i7 8700K @4.9 and 32Gb DDR4 4000Mhz can barely keep up at SS 2.0-2.5 in most of todays VR games (Im not talking about cheap Unity asset flips).
Of course its playable but reprojection is very apparent and nothing I prefer. Also, remember that Advanced settings doesnt always properly report reprojection if Asynchronous reprojection is enabled. Sometimes it says 0 reprojected frames while hands are a stuttery mess
i have a 1080ti but still hope that there will be some kind of reprojection so you only need 40fps for “smooth” gameplay
It seems no one noticed the double wrong calculation.
- Its wrong to compare resolution on both eyes (pimax) with resolution each eye (vive).
- 2560x1440x2=7,3 Mio Pixel, not 17,4 Mio.
Instead of totally wrong assumptions here an example for logical and good assumptions: http://community.openmr.ai/t/potential-performance-issues-min-spec/6597/3?u=kellerbach
It is the steam global value - just another place to modify it.
Hey Sweviver. I noticed you have a pretty hard-core PC there my friend.
May I qiickly ask, do you find 4000Mhz 32GB ram has measurable performance benefits in VR, say compared to 3000Mhz 16GB ram? E.g. do any of your own experiments spot a few FPS increase or a smoother experience maybe?
I ask as I need to build a new PC for my hopefully eventually launched, 8K-X but every article I find claims anything over 16GB ram is pointless!
I wondered, however, if when looking at VR snd total ram capacity/ram speed specifically if actually, things begin to change Vs normal gaming use on a single 4K monitor and more ram CAN benefit us?
If so maybe it’s now 64GB ram that’s overkill for VR and not 32GB?
Thanks.
I know you didn’t ask me, but my understanding is that 16GB ram is plenty, for today’s games; the RAM speed will have an effect, albeit a fairly small one. You are better off spending for a better CPU and/or GPU. I’d suggest buying the RAM as 2 sticks, so that you can later fill the empty RAM slots, if you decide it would be helpful.
if you plan on doing 3d sculpting in say oculus medium you will want that 32
Now if you want something interesting. My old system had 16g ddr3 1333 ram in 4 sticks. When I replaced it with 2 8g sticks at 1866? My 3dmark score dropped some & yes it was in proper dual channel mode. I am thinking this might have had to do with 4 sticks vs 2 to have 16g. Lol
And if you are interested in photogrammetry, e.g. in order to recreate your favourite place, your childrens rooms, etc. as virtual places in your PC to visit for trips down memory lane, then you may even want to consider 64 GB if you do not mind the extra spend…
There are a few games that gain from fast RAM, mainly high-CPU demanding games like Fallout 4 (VR and non VR). A switch from 2666Mhz to 3600Mhz could give u almost 10fps more according to some benchmarks. But 99% of the time, no the RAM memory is not that important. The cas latency is more important though. I run mine in CL16 3600Mhz atm which is better in benchmarks than default CL19 4000Mhz.
For pure VR gaming I think 16Gb should be more than enough. Not even the most complex simulators with high pre-loading uses more than 10-12GB RAM.
I have 32GB mainly because I do video editing. 32 is actually not really enough for more complex projects in Adobe Premiere Pro. Most video editors use 64 or even 128. I have had loads of Premiere Pro crashes because of lack of RAM (Adobe was using it all after a while).
If u dont edit, dont do 3d modelling or even record your gameplay, dont waste your money. Keep playing with 16Gb and save up for next GPU
Pimax he broke NDA. If you don’t take him away from his toy I will not play with you in the sand anymore!
I primarily play Rec Room and Tilt Brush in addition to The Lab experiences… I’m sure that factors in. Rec Room is incredible quality, and the graphics are simple (meaning simple meshes). Not sure how Tilt Brush stacks up compared to other VR applications, since it is very different in nature and scenes can contain thousands of pieces.
I’m now realizing that the majority of users play other games, but I personally find myself drawn to the three I mentioned because they exude in what I think a proper VR experience should be (I’ve only tried a couple dozen games so I know there is more for me to explore). I haven’t played racing sims because I don’t have a setup for that, I’m not really drawn to the current VR shooters out there (that I’ve seen), and games like Fallout 4 VR or Skyrim VR don’t feel like anything more than a camera locomotively moving around with cheaply integrated interaction with the game world.
So I guess if you have a 1080ti and play the kind of games I play, you should be able to raise the SS even when you get the Pimax 8k .
I have a ~2ghz 1080ti, Ryzen 1700x modestly overclocked on water, and DDR4 16GB @ 2666mhz (slightly underclocked because my PC would restart at 3000mhz).
Thanks for the reply, and an honest one too. I’ll take on board your suggestions and save for the best GPU possible with fast ram a certainty but huge amounts only a fantasy. Thank you.
I’d never heard of that thank you. It sounds really interesting. It’s amazing the variation in all sorts of knowledge people possess here.
Thanks for your reply. Well I’m limited to 2 sticks of ram due to my case being M-ATX as this can’t do Quad core anyway.
I bought it in anticipation of Ryzen 2 and getting into VR and now I see AMD partners aren’t making any M-ATX motherboards for Ryzen 2 with the ‘top spec’ X470 chipset. So I’ll have to just wait or go back to Intel and get a Coffee Lake 8 core unless someone turns up with something tasty.
Why AMD board partners are phobic of M-ATX ‘enthusiast’ motherboards heaven only knows. So weird, and Intel are getting more customers coming back also.
When you put RAM into you system you should account for Multi-channel memory. It will improve your RAM performance if your RAM is compatible and your motherboard supports multi-channel.
First, check if your motherboard supports dual- or quad-channel memory. If you aren’t going to fill all your RAM slots, then make sure that you are putting them into the correct slots (check the manual for your mother board). As an example, my motherboard supports dual-channel and up to four sticks.
Slot 1 - Channel 1
Slot 2 - Channel 2
Slot 3 - Channel 1
Slot 4 - Channel 2
So, if I only had two stick I would put them in slots 1 and 3. If I bought two more sticks I would put them in slots 2 and 4. Generally, when you buy a set of sticks they will be “calibrated” to work properly together in multi-channel. It would be best not to mix-and-match sticks from different sets (even of the same brand) on a channel, as they might not work as well together.
Edit: The downside of buying two sticks initially and two sticks later is that buying a set of four sticks may give better results in quad channel.
Good point. I was aware of that. 4 slots with dual channel (paired memory in same coloured slots)
Gigabyte 990fxa-u3d Amd board of course. But ram speed quite different 1333 vs 1866. But I do recall an Article explaining higher hz doesn’t necessarily mean faster depending on application. Latency if mem serves was lower on the 1333 G skill. The 1866 i think was sniper.
Intel I recall had tri channel for a time.
