too bad you can’t play with just kbm
because Pimax doesn’t have motion controllers!
some settings that I would like to share, because on 5K+ they really make a big difference
game settings is located at
%appdata%\..\Local\WrathGame\Saved\Config\WindowsNoEditor\
the first group of settings is to reduce the Temporal AA impact. The difference in sharpness is so big that I had to lower the resolution in game, no kidding. And the shimmering is minimal, almost non-existent in the environment, only a bit in the tavern
in engine.ini
[SystemSettings]
r.DefaultFeature.AntiAliasing=2
r.TemporalAACurrentFrameWeight=0.2
r.TemporalAASamples=16
r.TemporalAASharpness=1.0
r.Tonemapper.Sharpen=1.5
in scalibility.ini
[PostProcessQuality@3]
in gameusersettings.ini
sg.PostProcessQuality=3
This is to change the gamma, it makes huge difference in the caves. I know that we can also tune something with PiTool, but this works without having to deal with profiles.
in engine.ini
[/Script/Engine.Engine]
DisplayGamma=2.8
New Revive
Changes
- Updated Oculus SDK to version 1.41
- Improved frame blocking behavior to enhance performance in Unreal Engine 4 games
Bug fixes
- Revive: Added default bindings for Vive Cosmos controllers (#1340)
- Revive: Fixed Dance Central regression that causes fatal errors (#1334)
- Revive: Fixed menu button on the Left controller not working (#1339)
- ReviveXR: Fixed missing loader DLL oversight and added various fixes contributed by @qlyoung (#1323)
Hey glad to share this and thanks for watching! []-)
Oh cool… Thanks so much for sharing this… I am going to update the description of my video with this and give you credit of course if that’s OK?
Awesome… Thanks for sharing this because I had no idea there had been an update since I’ve been offline all weekend! []-)
Cool… keeps happening at my house too! [;]-)
did you test out the new version? does it work now?
Is there a way to change the angle of the hands with the vive controllers? When I am holding the sword it’s at the wrong angle.
This doesn’t work for me
Is there a trick to get it working? Do you need to press it in the center of the touchpads?
For how long?
I tried everything, but there is no menu
With PiTool 1.80 , 5K+ and updated Index controllers
Menu is left touchpad click (left using PiTool, Right using ReVive). Short Press to show actual quest, long press to enter menu
sadly they have edited adding this note:
This does not yet fully apply to Asgard’s Wrath, but hopefully will soon
Hello mmorselli, are you talking about the index controller or the vive wands?
Index Controllers
Thx Massimo, with your hint it worked when really pressing the left touchpad.
Was playing about 3 hours - really a great game
This game is amazing. Running like butter with your settings !
How good is it? Is it the don’t miss title of this time? Not looking for spoilers, i haven’t even watched any video’s.
I have (been watching) and decided to burn some money and get the index controllers- in hope that the base stations from pimax are delivered soon since I don’t want to miss out on this Titel.
Found out something yet?
Do you know if this happen when launched with revive?
I tried revive but controllers werent detected and since I updated it the game wont launch anymore so I use Pitool which is fine except for the tilted hands
