Again, I think they pursue the wrong way to do benchmarks. I created a thread on that topic but nobody replied.
That may because I am completely wrong or surprisingly it seems common that people do not think it through and have no idea what they are doing. In my opinion problems like that are very foreseeable.
SWE did the right approach in his last video (If I am not the one who is wrong, which I don’t know since nobody seems to like discussing it) but it is hard to compare it with previous results.
In voodoo´s video it shows from minute 1:20 2 comparison pictures, whereby the second is clearly more blurred than the first. His comment: I see absolutely no difference. Ok…
That’s not fair what you’re saying. Like @VoodooDE says, the upper part looks different because of the photo. Like he says it’s hard to make 100% correct photo’s because you have lens focus, lens angle, lens blur and lens sweet spot. Obviously the upper part is not like it is rendered in the HMD, that would be just crazy. He’s talking about the lower part in the photo. According to him that’s pretty equal.
I’d encourage you to take a step back and look at the big picture. Ideally, you would want things done differently in several ways, but the testers are all independent “contractors” with different equipment and frankly, this is not their primary mode of employment. What we are dealing with is a scattershot approach, and we just have to look at everything and piece a picture together. It’s dirty, organic and full of mistakes. The only other thing I can offer, is that if you are in a position where you are pressed to decide (like me) just don’t. Wait till there is a preponderance of data to drive you one way or the other.
SWE was smart. He used a Pimax 1, Steam 100 as a primary reference point.
- Then he experimented to find the lowest subjective quality thresholds for his setup and noted them as reference (and fps)
- Then he experimented to find optimal subjective thresholds for playability and noted them as a reference (and fps)
- Then he experimented to find upper subjective thresholds for quality and noted them as a reference (and fps)
That meant that he had 4 major reference points at which to compare to. So when Pimax changed the values, he could then find out where the boundaries had shifted and what that meant for overall quality and performance.
It is clear that Sweviver put in a lot of effort into his benchmarks.
voodo says
old pitool at 1.0 and steam at 60% has the resolution at 5443x2418
pitool v.76 steam at 60% has the resolution 2668x24418
if the new pitool give less resolution at 60% of course the fps and perfomance will be better.
he shows to images but says they are equal, but in my opionion i think the second its more blury because the resolution its worst.
I dont know if voodo tried 100% steam and pitool 100% in both pitool version, but i think he should try and compare if the visual quality its the same but with much better perfomance.
maybe even with less resolution, because the render is better the headsets have better image quality and perfomance.
Or you could just record the reported rendering resolution in SteamVR (if available) and make it the reference point. Then just setup PiTool and SteamVR SS in a way the rendering resolution matches your target. From @VoodooDE video it looks there is a clear relation between FPS and the total number of pixels rendered.
legend. thanks for translation
The rendering resolution changes when Pimax makes updates…and it is hard to target exactly the same resolution. This is why Thomas was annoyed. (apart from the other factor that his chosen percentages were rendering at a much lower target resolution)
Well he made already load of through the lens photos and is well aware which aspects may deal with the trickyness to do those photos. So I very much trust his judgement on this one, even if the photos do not look alike for us. He also states, again, that it is a sob to do those photos. I also agree on his theory that of course the new way to do the Res-Math is leading to higher FPS. The results though (little less RES) should not result in that much more FPS than shown by SWE. So I guess its a mix of both. Pitool sending a lower Res on 1 + other (real improvements).
And again this way of benchmarking is not leading us anywhere!
On my monitor, the lower part is also not the same. The right picture is smeared, all key letters are more fuzzy. I believe that he observed no difference in HMD, but the pictures he used to prove the point were not chosen well.
He may have missed the point that if he saw absolutely no difference, and the newer update resolutions were lower (thereby increasing performance) then it means the updates made improved quality levels as it needs to do less work to provide the same result.
Agreed, he should have shot a better 2nd pic
Sorry, I almost never take a step back, except I know it will take me 2 steps forward later on. I very much look at the big picture, and I encourage everyone to reveal my flaws that I am unable to see myself at times. But I need to know where I am wrong with precise criticism. They have the same equipment to measure FPS, I’m actually suggesting a way to make it easier and proved successful for me many times, which still does not mean that it is better.
I know, I saw the video. My point was about how to set up (somewhat) reliable reference point. The only danger I see is if Pimax starts to change transmitted resolution to the headset (or to be more precise the active area of the input resolution), for example instead of rendering full 2560x1440 they will let the PiTool to render only center 2200x1200 (because what is out of this area is not visible through the lenses anyway).
This way they could reduce rendering burden, while still maintaining the same visual quality. Then using only the rendering resolution as the reference point becomes useless, (at least for the quality), because you could have the same quality while using different rendering resolutions (one would just “better” fit into visible area of the panel). In such case, the testers would also somehow need to assess the image quality and its eventual degradation (or not). Which seems to be much more difficult.
Yeah that is why I was saying Sweviver was smart with his approach. They should have all known that Pimax were likely to keep adjusting settings and accomodated for that.
Voodoo’s mistake is that he believes the percentage in steam is authoritative. Only the render output in Steam is decisive. And since you can equalize both in both pitools, you can compare both versions regarding image quality and performance. Common sense.
The adjustment of pimax in the new version makes sense: steam generated too much resolution before.
edit: As long as everything is still in the testing phase before release, the accusation of fraud is simply stupid.
Once @Pumcy receives his headset & may have a more standardised methods for testing writing Articles.
Keep in mind we are not seeing what he is. We are watching a recording that might not reproduced as things would in real life. The same token with through the lens shots.
Indeed without rigging for consistent repeatability it’s not that good for referencing to.
