fov is very small (like a shape of egg). Look not natural because the edge is grey color.
very dark, need to adjust contrast to be 2-3 while brightness is zero. But will have issue with white scene.
It look I feel less of vertical line, but not sure because it look using different brightness (5k+ has high brightness although using the low brightness).
How did ISLC mess with driver installation ? What happened exactly ?
I use it and did not have problems with latest NV driver installation. I did not try the new pitool yet, though.
Yeah funny thing though, I donāt mind flashing modified firmwares to my GTX1080Ti or modifying my MB bios on my own and flashing that, but this piece of hardware⦠My Pimax gem wouldānt want to screw that up cause I use it every Day
I usually freshly install drivers on updates. It broke the new Nvidia driver update mid installation, and broke its own rollback function, took me down to 1 out of 3 monitors, and only a removal in device manager and a following restart solved it. ISLC killed itself while doing so, sent me an error message in a popup, thatās why I know it was linked.
