That will be correct if you have your eyes in your neck, which appart to be funny and disgusting, your neck is the exactly center of the angle made with your arms-hands in 180 degrees.
Unfortunately, its wrong trying to measure with this trick unless you are taking care about this detail: your eyes are around 20 cm ahead the measurement center.
With the arms in 180 degrees It is really hard to get an idea and same measure will be different depending of the physical constitution of any one; some people have long arms, (it will correspond in less degrees), short arms (more degrees), different physical constitution; hoity hoity people will see their hands close to 180 degrees with the arms in 180 degrees, and if you have a really bad day or a neck problem your hands will be like in 240 degrees above your eyes, huge head in relation with the body = more degrees… and so on.
Even the distance from your pupil eyes to the lenses could give you even 10 degrees more, If you have access to an htc vive try to remove the foam and check what you can see with or without the foam,just getting your eyes close to the lenses. HUGE DIFFERENT.
I try the V3 in NYC and I made the same measurement with my arms, and taking care about this detail I will say that I saw around 200 degrees, knowing that with my hands in 180 degrees with my back I barely see my hands that should be like 220 degrees for me.
If you want to know the exact measurement you will need to use an app like the one in this threat: http://community.openmr.ai/t/real-o-virtuals-free-headset-test-tool/5748
But again, Even with that tool, If I see 200 degrees the person next to me could see 220. I DONT CARE, WHAT I CARE IS WITH PIMAX 8K I WILL GET LIKE ALMOST TWICE THE CURRENT HEADSETS FOV!!
What I meant is, THIS THREAD IS POINTLESS. Comon guys, forguet about FOV, Im sure that even with a little less I saw with the V3. I will be happy with even 150 FOV. With the V3 I didnt notice SDE, and NO GOOD RAYS. I dont think they are going to have now SDE and Good Rays.
The important point here, the real questions you guys must make to Pimax is what about the software, how is the status of the firmware version, what about the integration with SteamVR, Do you have PIMAX direct support from STEAM to make your headset run without your PIPLAY software even in example if the displays just gets 80 fps. Thats what you need to be worried about.
