Few words about the IPD thing.
Yes the minimal distance between the two lenses seems to be in the 64-65mm zone, and yes if you have a 63-64mm IPD and you want to look at a point with a perfect clear view on both eyes at the same times, you’ll have to put the mechanical IPD at the minimum.
But does it mean you are supposed to do that?
That’s what I thought but I’m not sure anymore.
I mainly play simracing with the 5k+, that I have got 6 weeks ago, and my everyday game is Assetto Corsa with the content manager, shader patch and SOL.
Recently I have started to play on large mode, for immersion,but even when I played on the normal mode, I was applying the IPD trick discussed on this topic. : putting the mechanical IPD at its minimum. (my 63 mm IPD minus 3mm=60)
I had clear view, but something was off on the world scale, didn’t know exactly what.
I have experimented a lot, switching between 3 software IPD offset : default, +0.5, +1, ended with +1 and always hardware IPD at minimum so the pimax told me I used a 61mm IPD. (60mm + offset 1)
But something was still OFF.
the most awkward thing was how the other cars didn’t really have the right scale.
they looked real just in front, but when they were going away, it was a bit like they shrink rather than being further away.
Nothing as dramatic as it sounds like, nothing obvious, but something was off, and I wasn’t really 100% there. the roads, and the sens of speed weren’t 100% right neither.
But recently, I pushed the mechanical IPD further, and after a lot of races on different tracks, different cars, I came to a total of 63 mm (which is my real IPD).
Then, WOW, I was really there, the world scale looked real, the way the other cars behave when they are getting further or closer was right, the roads and far distances were right, and the sens of speed was legit.
Despite the distance between the two lenses center was higher than my real IPD, my eyes weren’t seing fuzzy images and above all, the scale was right, and so was the immersion, which is the most important to me.
SO, I’m not sure now that the indicated IPD on the screen is OFF like most of us may think.
ON my experience at least, this number is way more legit than what we can think if we only consider the center of the lenses and place the clarity before the sens of “really being there”.
The eyes move very often, so maybe it’s not a big deal if they don’t look at the center of their respective lenses at the same time, the brain probably accommodate anyway, which could explain why I don’t see any fuzzy image.
