I think Kevin from Pimax USA said to Sebastian at CES 2020 it’s improved to 80Mhz maximum for 8K-X, and nothing about 90Mhz, so I wouldn’t be too hopeful for higher refresh rate.
From memory, the max Pimax ever got in testing months ago, but wasn’t stable, was 82Mhz.
Perhaps if we’re very lucky, Pimax will offer a Fiber optic cable, to increase the Mhz higher than 80mhz? I don’t see any other way after a long time testing though, that this will be possible.
Regarding Sebastion’s thoughts on the MAS and comparing it to the Rift S, one thing to think about is that CES is a ridiculously loud event. Perhaps his review of the MAS will change in a normal environment.
he definetly said it was not index qaulity audio, he was very sure of it, its unlikely to change, otherwise the industry standard would be this headphone type.
This my question too. It seems to me that these high hz are not native to the screen and are using the brainwarp technique talked about in the kickstarter
We will soon post a update on all our models, please kindly stay tune on the discussion.
All problem will be answer throughout the discussion, as we are now sum up the questions by our users! Please spare some time with us and everything will be reveal real soon!
It’s very interesting that the XTAL guy (VRengineers or however it’s spelt CEO) states they solved the issue of poor depth perception and eye strain by putting a lot more work into the warping algorithm.
My biggest problems with pimax hmd is no depth perception and crazy eye strain. Maybe it can be solved if pimax put enough work into their algorithms.
