so there are 2 audio plugs now for left and right. hope i can use my headset normally when plugging it into just one
Im slightly concerned that he kept saying the audio was “usable” and that it was comparable to the Rift S.
that may not be good enough for me, I want deep rich sound.
Can we easily buy the ear cup version (deluxe) and swap easily between them?
I wonder if the Deluxe Audio Strap headphones can be placed off ear like on the Valve Index.
nice. Im getting a woojer audio strap so maybe it can compensate for the non deluxe audio by providing the bass.
I assume the MAS plugs into the headsets audio jack like the DAS does
I pledged for a strap too…
I was pretty sure of this about the Artisan, well done Pimax, this is going your top seller headset.
depends on the price did they announce it yet?
449$ without tracking and audio, 549$ with tracking and not sure about the audio
I was considering the price in what I said, of course
They would be silly to not allow you to do that just to save a few bucks(per hmd). The quest also has two audio jacks and it works fine.
very smart. Better than the index in both specs and price and with the smaller fov probably eliminates any distortion.
I wonder if the MAS is compatible because that would leave no doubts
audio solution is “comparable to the Pimax 4K speakers”
it kind of has to because it needs to be compatible with existing 5k+ and 8k which only as 1 audio jack
Oh yeah right…hmm
Well, I dont see why it would not, the MAS is basically just a strap, unless it have no jacks.
Weird…but if no jack then no sound at all lol, unless you have to cut the cable to change sound system.
Ok was just thinking about this, Sebastian was trying one with the DAS on it…so…I guess they just forget to add it on the slide ? Maybe lack of space lol…but it is actually weird
If they where just wires then Kevin would not have specifically mentioned them in the interview. So you have nothing to worry about.
Fun thing, Sebastian just told Robin the same as I do to my followers, Pimax should keep only 2 headsets, the Artisan and the X. ^^
I am pretty sure the Artisan is going to be a big success
The FoV
The refresh rate
The image quality (Index like, better than 5k+ according to Sebastian)
and…the PRICE !
