Device Detected as Illegal, please contact after sales support message when starting new pitool 262?
For some people, yes…
okey hope they fix it assap
my 8k pluss is illegal. so maybe just wait for 263 maybe.
If you write to support and give them your serial number, they will add it to their list and it will work for you.
the full pack comes on Wednesdays, i heard
PimaxQuorra pittol 262 not working , illegal hmd it says.
s/n20630420500667
There is a recent topic on this. Please send @Alex.liu a pm with serial number and details.
Estimated not guaranteed is what I was informed with being given the release.
I will ask @Alex.liu as yes this detail should be in the release notes as this is quite a huge miss and will affect many. I haven’t had a change to test this version out as of yet.
Or if for some reasons internet at home is unavailable?
This is a VERY good point. What if internet doesn’t connect, what happens then?
then the same thing happens as with the steam server
Nothing Happens as with Steam you can play offline. If pitool requires the internet as mentioned above it could be a different story.
Either way this needs to be fixed.
Really? There is a way to say ti steam, dont call at home? Crazy
Hello,
This issue should be resolve right now, the SN has been updated.
Sincerely,
Quorra.Pimax
You can “go offline” voluntarily in which case steam pretends you are offline but actually still keeps tabs on you. Then you can actually be offline such as no internet connection, in which case steam doesn’t call home but you can still play (most games).
Why do I get the feeling that there will be ‘cracked’ versions of pitool showing up or source code with removed security to run these headsets in the future…
The plan is to open the source code. Then we can remove (or add) anything we want.
My understanding is that only covers the PiTool code. Nothing has be said about the drivers, which probably will not be made open source. Likewise nothing has been promised regarding the new “Experience” app.
Sorry, why do pimax serial numbers need validating…?
Is somebody producing knockoff pimax headsets that run via pitools?
