EDIT: Well just found out that the North america support has been shut down. Everything is in China again. Way to go Pimax!!! Keep up the great work…not!
EDIT 2: Screw It! Ordered the thing. Will let you know how it works. The only difference is the adapter for the headset. Will see if I can mount it OK to the Pimax…fingers crossed!
Thanks Kevin. I ordered it anyway. Should have by Wed. If I get it to work…cool. If not,I can get a refund. with purchase price and shipping…still less than Pimax. Plus, no telling when you guys will release the Pimax version, not a backer… So, I thought I would give it a try anyway.
Also, really disappointed that you shut down the US support center.
Best,
David
Yep, already been there Kevin. Saw the coming soon. Based on my past experience with coming soon from Pimax, I wanted to do something. I have requested an email when available.
If I can purchase one soon, I certainly will do that. If this works, at least I have something, until you do get them in stock for shipping. I can get a refund from Mouser, so not too worried. Unless it will take months for the 700 units to arriive…“this week”
the only downside is probably that you’ll have to figure out your own mounting and suposedly the pimax version should have an extra wide tracking area but i’m not sure if that’s actually a real thing since i don’t recall seeing them hyping it up lately.
The tracking on this version is actually considerably wider than the fov of the headset itself. It can also detect hand motions closer to the sensor than before.
As there just seem to be a handful of backers that received their HT, can you share some experience that you‘ve made so far?
Have you tried it on a 8k/5k+ as well?
If so, do you think it works as good as with the 8kX? (in terms of performance due to the usb variances)
Is the HT configurable or just for games/apps that explicitly support it?
e.g. for a boxing game + basic gestures for menus
@noro: Just wanted to let You know that I haven’t forgotten about You… Testing the hand tracking module is on my ToDo list (and a whole lot closer now that I have room-scale working with extension cables)…
Nice, thx!!
Keep me updated on your extension cables as well if you find the time.
I did a 10m extension for my OD+ and It has been quite a ride…
After testing literally loads of usb/hmdi cables + repeaters and drivers for a usb 3.1 pcie card, I finally succeed though. (posts should be somewhere buried in this forum)
But when my G2 arrives I‘ll need to go for displayport…and as I also tried many cables to get my 4k screen on above 60Hz. Also here getting a 2m cable was some serious try and error. so any suggestions for good displayport cables are appreciated
