Wireless / Wiredmode Plug
Hi
I just installed the TP-Cast @ my Vive. It would be great if Pimax creates a solution which makes it easy to change between wired- and wireless mode. For example if playing racesimulators (or any seated experiences) it would be good to be able to just use the cable.
On the vive i have to remove the top panel on the hmd to change cables. An easyer, faster solution on Pimax would be great.
Looking forward to the 8k. Good luck an keep up the good work.
A post was merged into an existing topic: [SUGGESTION] Wireless Powerbank Switching
