Driver4VR (ver 3.60) with Kinect v2 has improved the PSMove tracking to tolerable on my side.
The PSMoves are actually usable for Front Facing content.
So with your setup are you ust using Kinect v2 with psmove controllers? Or are you still using ps3 cams?
Have seen progress being made on ps4 cam (the spec connector is just a usb3 port)
PSMove+Kinect v2 (PS3 Cameras not needed).
Maybe the option to double up on Kinects will arise for 360 tracking at some point, like Kinect v1 & v2.
The problem now is 50% cpu usage with PS move controllers via light bulb tracking
I just managed to get kinect 1 skeleton working reasonably well, with 1 psmove controller. Not too much shaking. As soon as I used the 2nd it freaked out. Progress though. Unfortunately Leap is broken. If he fixes it I can see it finally being a good setup.
