More than a few of us have BIG issues with tracking via LH2.0 so this got me thinking if itās channel related (probably not at all) but it could be worth checking anyways.
my tracking looks like this.
So if you have an 8Kx in you possession and LH2.0 and stable tracking.
Then please post what channels your LH2.0ās are working on.
please do not post if you do not meet the criteria posted above.
My received 2.0 basestations from Pimax are solid white when turned on.
That being said, havenāt noticed any tracking issues.
The left basestation = ch1 & the right basestation = ch2.
I donāt think itās related just to the 2.0 version.
When I received the 8k took half a dozen teamspeak sessions until they found out a way to bypass windows permissions in one of the most recent version of pitool and it was working great with LH1.0 at the point I sold the Reverb because had worse tracking (I do simracing competition on a motion seat).
Now that I got the 8kx not only I canāt have it to link with the lighthouse no matter the pitool version, but I lost tracking with the older 8k.
I wasted the whole day yesterday trying every kind of troubleshooting I could find, deleting folders, reinstalling applications with no luck.
This is not a hardware issue, just a pitool configuration that doesnāt talk with the valve lighthouse and Pimax did not sort it out yet after two years!
Your video is too low res to read channel numbers with absolute confidence⦠whatās the first one, 6?
Btw, i have bad tracking jitters, similar to yours. Very annoying in cockpit games where the cockpit up close would jitter all over the place, to the extend that in real scale, a cockpit frame would move 2-3 cm on its own.
yeah sorry about the low res, guess itās pretty bad Channels 6 and 2
This video was produced just for my support ticket so they could see the tracking wobble.
What channels are you on ?
comment: This topic went south pretty fast, I was asking for people with 8Kx + BS2.0 that has Stable tracking
Thanks for posting guys, I see that there are more of us than I anticiated.
Please edit your posings with BS version and channels used
OK, so just for the record:
I originally had 2 x 2.0 Lighthouses (purchased from Valve) then added 1 more HTC 2.0 basestation to try and reduce jitters. Didnāt help.
Itās from memory only but I believe 5K+ tracking was much better with the same basestations.
Now I have jitters with 3 basestations. I tried various channels, I think I have 6, 13 and 14 but Iāll doublecheck and update the post.
Actually itās not totally limited to LH 2.0 either. I have 1.0 LHs and still get some tracking wobble like shown in your video. It is not as bad as what your video shows but it does happen enough for me to notice it.
Indeed. Maybe support needs to check things from a remote session. In theory the 8kX should have all the bugs of the og 8k and 5k+. The fact the 8kX is not restricted to USB 2 bandwidth(though neither should have the pre 8kX headsets); it should have more stable tracking on USB 3.
Yeah thatās the āfun partā when I look at my ticket, the tech assigned is Doman Chen
But the people who have contacted me āwritten in the ticketā is aaron and miracle.
So the ticket might be assigned to Doman Chen, but heās not handling it.
Hopefully this is due to the hollidays i China now.
And while all this goes on our very limited 1 year warrenty just āpissesā away.
Iāve had mine delivered 11 days ago, and add another 5 days to that before they are back @ work.
And then how long will it take for them to try and debug⦠next think you know iāve had a defective 8Kx for 1/12th part of itās warrenty period ⦠am I a pessimist ? not really⦠this should have been caught in QC⦠the QC that had been extended and made the delivery time longer, as they wanted to make Sure that every one got a fully functional 8Kx⦠Geez
ārant overā
Interresting⦠.are these Valve 2.0 lighthouses or HTC Vive 2.0 ?
Mine are Valve 2.0ās bought directly from Valve less than a year ago.
They light up Green when ready.
So now we need to compare firmwares on Formatterās and mine
Seeing they are both 2.0ās but behave differently and shine the Diode in a different color.
