Yes it seems to be great value. I see saints and sinners is on itās way. Iām a bit sad if itās on infinity because I paid for it on steam and could have waited. I downloaded yupitergrad but canāt get the controllers to shoot? If you have a fix let me know.
Viveport is good because so many vr games are either too short or arenāt as good as their price tag. That being said I bought TWD and I will still buy a game on steam if it is on sale, if it is something I actually want to own.
But with smaller titles I have learned to back off for a dew weeks, because Iāve been burned. I bought Boiling Steel and wasnāt very impressed, then it showed up on viveport a couple of weeks after i bought it, That also happened with Battlewake.
I switched to my vive and it worked. Also just retried the Pimax and now it works. Have a controller constantly vibrating but it worked. Worth checking if you like comic book graphics and spiderman type locomotion similar to Windlands.
Moss is Infinity. WOWā¦ canāt believe they did that never bought it because of the price. Now I can check it out for my membership. Looks amazing on my 5k+ must be truly breathtaking on the 8KX. Please let us know how it is on the X.
I wonder how it works on the technical side? I understood (not from the viveport website though) that I would need another client app, but then will the game install into SteamVR lib, or they are completely separate and only use SteamVR for VR runtime?
I just bought a Vive Pro and apparently there was 2 month trial for āViveport Infinityā and I wonder if it is worth the hassleā¦
games are stored in a separate place of your choosing. I choose D:\Viveport
But they run in steamVR.
you must remember SteamVR is really OpenVR and has nothing to do with steam.
If you close steam client and run a viveport game it will still work.
Dude if its free iād urge you to try it. Donāt be like those dweebs from FReality. Who get all their games for free and dare to tell us about āvalueā
There are so many iffy VR games and some really goid ones. The amount of iffy games Viveport has prevented me from buying paid for the subscription 4X over.
Knowing my luck Iād cave and buy Medal of Honor for $80 and a month later it shows up on viveportā¦ lol
check out this laundry list of games on infinity right now
When Viveport was first introduced, and for a long time afterwards, it was so bad that it would crash your computer, along with having a myriad of other issues.
Although I havenāt seen any reports of issues for a while, that was originally because no one would touch it.
It was also made by HTC and, at the time, we were so mad at HTC for their lack of warranty support that no one wanted to support them.
Is anyone having issues with it anymore?
And, as long as Iām asking, whatās the difference between Viveport and Viveport Infinity?
Does it come with itās own VR launcher? I remember that we used to have some software that allowed us to place āplaquesā of all of our games in a VR environmentā¦ but I canāt remember what it was called.
Thanks!
