Twack3rs Varjo VR-3 impressions
Once again here is the version without motion blur:
So what’s your point? I’m not sure what you’re trying to say.
Your headset is less than 20ppd and your trying to argue its comparable enough to a 35ppd headset that doesn’t even have its 70ppd focal display on…lol man let it go…its just a youtuber test, everybody knows sebastian gets super hype over the latest and greatest…but the numbers are the numbers man…OMG
Maybe Varjo should consider making a consumer model without the Bionic displays since it seems they might not be needed due to reports of them not being active. And remove ET. With of course fixing the distortion issue described and sell it for the price of the VP2.
Varjo could easily do this with the Enterprise spenders paving the way for there R&D.
This is a limitation of SteamVR and the OpenVR compositor.
This does not apply for native Varjo compositor apps or OpenXR compositor apps.
Here is the image you posted:
Here is my grab of the same program in an 8kX:
Which one can you see the word ā€œArenaā€?
What about my statement was hostile? The mental math this dude is taking to say his sub 20ppd display is comparable to a 35+PPD system which is over triple his headsets price…is actually disturbing…OMG david…ewww
It still stands though that you are not getting full benefit of the bionic displays in most use cases due to XR not being that strongly adopted yet.
However it has a great picture without them being active. So imagine if HTC had taken the GearVR aspherical mod to heart and developed the VP2 with Aspherical it might have given them a real edge.
something is wrong with you dude, nobody said 8kx is on par with vr3 but its close to g2 but not as sharp as the g2. the point was that g2 and 8kx was shot significantly blurrier than they are. And most likely its done on purpose, the video in previous state made g2 and 8kx look much more inferior to vr3 than they are, but most probably you are a troll or have some personal issues with pimax as you constantly take words out of context and follow your own pimax is as sharp as vr3 thread
To what end? He apologized that he made a mistake, reshot his takes and they now match very closely what I see in my 8KX and G2.
So why not buy an Xtal 8k and see if the lower ppd is as big of a deal as you think it is?
Yes it should be quite clearer. But by your own math the Varjo cannot even come close to the Xtal 8k as it costs 2x+ that of the Varjo. Which btw VRgineers was impressed with the 8kX.
I said nothing of the sort BGAStories. I think the Varjo looks awesome.
My thing is merely that there is significant motion blur in the pimax images and I was able to post identical images that demonstrate this. I am merely pointing out even the updated images from seb can be considerably better which I have shown. I even said do not blame seb for this.
It’s funny how everybody seems to draw their own conclusions from the same vid :slight_smile: The text compare is actually really accurate. The video of the game too. The still shot of the game could have been better, I agree there. But ā€˜on purpose’, if that was the case then sebastian really did a bad job of making the 8kx look bad :slight_smile: It’s actually pretty good in the text compare part and also in the video part of the game.
In the game part I agree. but like I showed before, your comments about the text make no sense at all.
I don’t think Seb is doing this either. He just is still using pardon the word archiac method of doing ttl shots. You really need a proper rig as mentioned that @Tyrielwood has put together if your going to be serious about ttl. To ensure repeatability and more reliable accurate captures.
Optofidelity would be a great way to truly compare headsets.
Actually seb’s lines 8-11 cannot be read, my version same image all 11 lines visible and readable.
And one more time do not blame Seb, I don’t and others shouldn’t either.
I can read it from the photo. Line 11 is a bit difficult to read, exactly as I find it a bit difficult to read in VR on the 8kx. On the VR3 it is easy to read. So again, pretty well depicting reality.
even now some stuff like this steam vr menu hell split arena titles not in focus and done worse than any hobbyst will do. Its nots about this single video, when mrtv reviews a hmd i noted not once that compared hmds got shot way worse than in previous video where he was promoting those hmds, its not about pimax at all. i never saw such a conflicting ttls on other channels and considering his experiance i would say he clearly notes how its shot, why its like that - who knows, but ttls inconsistency and some pattern for artificially create the difference between hmds is quite obvious for me, thats the reason i stopped watching his channel and sometimes see his videos like that coz thay got posted on the forums i am part of
So what is the purpose?
The biggest problem is we are not necessarily seeing the pics in full res without compression and such being applied.
I recall Seb being rightly upset when someone criticized his ttl due to him broadcasting his channel in 1080p.
Focus more on what he says. The pics are just visual aids to give a static idea.
