@mixedrealityTV
Weight
Did you forget to tell that StarVR One does not have an audio solution ? So what was your aim when you have compared accurately the weight of StarVR One, Valve Index and Pimax 8K X ?
It’ s like comparing an apple with two pears
FOV, Distorsions and RESOLUTION
StarVR One have made a good work with FOV and distorsions but this headset costs $3200
Instead Pimax is a platform for consumer large FOV headset costing
Artisan $449
5K PLUS $699
5K XR $899
8K plus $899
8K X $1299
and don’t have eye tracking for now
I am sitting in front of my 27 Monitor and i have at my left a big hp printer
The printer is at about 180, if i move my eyes i see the printer,
it’s not correct i see the shape of part of the printer (where is the display)
for few seconds because it’s hard to move so much my eyes
If you replace 10 at left and 10 at right with a black zone you have PIMAX LARGE FOV
If you replace 20 at left and 20 at right with a black zone you have PIMAX NORMAL FOV
and you know how much big is the FOV gaming at 140
What is better 3200$ StarVR One useless extreme FOV Or $1300 Pimax 8K X resolution ?
But at $3200 you said StarVR One is really really incredible …
“Some of the objects stop to render when they are in the peripheral vision”
really really laughing of your first impressions of StarVR One
Are you in your MRTV Headquarter’s ? Yes, you are
CONFIGURATION
Rift/Rift/S GAME
cpu I7 8700K gpu 1070 The walking dead
cpu I7 8700 gpu 1080 Stormland
cpu I7 7700 gpu 1080 Asgard Wrath
Since you tell you are a a reviewer I don’t know how you thought to make a review of Pimax 8K X (that should work at the recommended resolution to apply the distorsion profile) with your old PC
If the PC is slow for that resolution/game , you will have issues moving Head in your vision.
It’s not that Index 120 hz are better than 8K X 75 hz,
It’s your PC
Pimax 8K X is not RIFT S
@PimaxUSA
@SweViver PC is the recommended configuration for native Pimax 8K X
No one buy Pimax 8K X to play fruit ninja
