Heads up, looks like some players having luck unlocking the steam preload early.
EDIT: It appears to work. I shut down steam following my preload, changed my VPN connection on my computer to New Zealand (and also changed my VPN on my phone to NZ, apparently it checks my phone too as Authentication it is me)… fired up steam again, and the game is unpacking. Sweet.
Bummed about PP needing to be enabled. Performance on my 1080ti and 8KX is likely going to be poor.
Interesting counter-point: Norm from tested apparently able to play on index at 150%ss at 120/144 hz on a 2070 super with all VR specific settings maxxed out… still hope
Yeah, we truly won’t know for sure until we run it ourselves. I’m bordering on it running ok, but being a bit rough at times. At least until a performance patch is released.
I can confirm: parallel projections needed. Unlocked through VPN.
There is an issue which causes the rendering to feel choppy, even when running on full panel refresh rates. Had to lower a lot of settings on my 8K-X though to get there, something like 2600 vertical resolution, plus some eye candy turned low.
Rate issue? I usually play on Small so maybe it’ll be a bit better. I play games at like 60-70% SteamVR SS on non-parallel and that’s acceptable, which is what SteamVR recommends. I get this with Parallel…maybe it’ll be ok…
Just tried the first mission, will have to come back to it tomorrow. Seemed to run OK and look pretty good on the X with standard PT 1, FFR and SS On. Haven’t adjusted any gfx details yet, just configured the HOTAS. Didn’t see any skipping but I’ll grab the new driver.
