Why don’t Pimax come out with their own version of motion simulator for the cheap. Building it cheap in China, i am sure it will beat anything in the market in terms of price. Do a Kickstarter just like Pimax headset and see if people are interested lol.
I also bought the yaw vr because its easy to put away…its a fun device for the price…
But you need to be carefull not to put to heavy pedals outside the Shell…
So its better for flying games like elite dangerous…Or xplane 11 or dcs
I have a cheap lightweight Wheel with pedals on it and its still fun thoo
@twack3r
T3pa pro (~7KG) are too heavy.
Standard t3pa should be ok (2.8kg)
This is not a good idea.
It was discussed a lot early on & tried by an early backer a few months ago.
He put the t3pa pro pedals (~7kg) on it & a lead counterweight on the back.
He burned out a motor.
It’s too much weight off center & builds too much momentum.
The wheels start to slip, the motors start to overheat.
The team has now recommended 2-3kg pedals
could you take a recent picture of the wheels you set up underneath?
Im seriously considering building one of these myself
Im also thinking that I could make a pedal compartment attached to a rail underneath so that when i want to race i could just pull the pedals out from under and not have to worry about them sliding around since they would be attached to the chair.
Im also thinking that i would put a hole in the hotas arms for one of those led marine cup holders when not using the hotas
