Ok once I have done some tests with dirt rally, i will let you know. You cant get heave from it but bumps could be assigned to pitch axis.
Tbh it’s all about setup & what/how You assign forces.
So far the yawvr game-engine plugins are all new & fairly basic.
They are plug & play though so it’s a nice touch even if they still need work.
Athough I have simtools, i havent learned to use it yet. It’s very complicated.
The turning sensation feels really good in planes & rollercoasters at least but I will say most people are not using yaw or at least not much yaw due to wire limitations & no motion compensation.
This is actually still really good & is how they demo the unit.
When I’ve used full yaw, I’ve done it with usb extensions & hmd cable coming from above but you do need to be aware that your wires can & probably will start to twist.
The 360° per second will be more marketing talk & less useable. That would be using full power which would be flinging you about & not feel good.
Another limitation to using wheels & pedals is you need to be aware of adding weight. You can’t put a heavy 5kg + set of weighted pedals on the footrest. Need to be kept as light as possible.
I have thrustmaster t3pa @2.8kg & I believe these are towards the upper limit of what is recommended.
Also they have not created a proper pedal foot plate yet so solutions people have made so far are made of wood, while we wait.
It only ships with standard footholder plate.
I personally dont get any bad feeling from the spinning on what I have tested so far ie… xplane & no limits & neither have any of my family.
I am completely immune to motion sickness though.
Personally I find the position fine & I have spent 3+ hours in it in one go. But if you are quite tall, it might be different.
The 45° angle thing to me feels good & once you’re in vr, you pretty much don’t realise. At least that’s how I feel in flight & rollercoaster.
I haven’t heard any complaints about this on the discord server or from my family.
But you can calibrate its start position anyway. So you could calibrate it pitched forward a bit if you wanted & lower the forward pitch limit to compensate.
If car racing, you probably want the limits low anyway.
I made a base to raise mine 10cm & it gives much more useable pitch.
You can set it up through phone app or Windows app.
I think i had to search for it on my phone first time, but windows app is more stable so I only use that now.
It only needs a power cable & autoconnects to my router on start or could be wired to it by Ethernet instead if you wanted.
You will miss your buttkickers.
It has built in vibration but its early days & works better on some plugins than others. Some not at all.
& still hasn’t really been set up to work well for most games.
It presently can’t be used with standard sound as a buttkicker could either.
Edit today they released a test showing tests of it vibrating from standard bass so I guess that’s coming at some point.
For now i have been using my woojer vest in xplane11 for some feedback.
I’ve been using with index & cable management is from above via pulleys. But I really want to go full wireless.
I dont think you will easily be able to use full yaw with power cables etc…
I am using the pro version & I would recommend not getting standard as there is no headrest. Amongst a few other small things.
It only comes with 2 plates standard, so I made a plywood plate in the shape of my wheel base. I then drilled 2 holes for the wheel bolts.
Then I used Velcro to stick another piece of ply to the base of my keyboard which has aligning bolts.
So I just undo the nuts to take the keyboard off & can then pop the wheel on. Although I haven’t used it yet.
You can order extra plates, but I hadn’t & needed to make something up quick
Although I haven’t set up my wheel & pedals yet, i would say if driving is your no:1 use case & you have little interest in flight etc…
Maybe hold out for more driving reviews.
Because pedal weight, wheel position etc. Are probably less ideal then on a standard sim rig.
I will test myself within the next week or 2 though.
Personally, if I was asked to recommend this to someone who only sim races, i would say probably not the best thing to use but should work ok.
But maybe look at seat movers in a similar price range instead.
Or a full 6dof actuator setup if you have a permanent home & 5k - 10k upwards.
But to me it is much more than for only driving & the space & flight Sims interest me a lot.
So I would definitely not pick a seat mover over this for my use case
