RTX 30 Series Discussion - Part 2
This also looks pretty wild… :open_mouth: I know it’s a benchmark, but still. Did it somehow utilize the memory or?
Also, looks like I will finally get back to playing FO4VR (I’ve been saving it or most of it):
Just need to look into fixing the weird controls with the Index controllers (I know there are workarounds), oh find a working DP extension cable (or wait for fiber optics).
@NextGenVR i tested just yet the same settings as voodoo(200% steam and on my valve index) with my gigabyte eagle oc rtx3090,now i see that my card is functioning good.
Except you did it at 120Hz instead of 90Hz. Great result, dude.
damm i didnt see that,does it matter or will it be the same?
I have no idea. Seems weird that you got so much better results with higher refresh rate.
Hmm, only 7x% usage for the ti. The temps are much to high… voodoo needs a waterblock, quickly
But them gainz, bra!
Yeah Voodoo’s 2080 Ti performance is pretty average but I believe that’s also good info for the average user.
Only bad news in the video is for PC3 and DCS players.
Looking forward to the SLI benchmarks, but it will most likely be disappointing(as always)
evga 2080ti black shunt modded with palit bios = 28.41 in openvr at 2848x3168 resolution
I think I hear my wallet crying! :rofl:
It’s all starting to look good now. Should be a pretty epic upgrade from the 1080ti.
I will wait for amd’s navi range 3080 performance 240w with 16gb mem for £600 ish
could be overclockable too
could you run it again at 90hz please
want to see if the 120hz caused any anomaly
So still no real news then!! What we need is a direct like for like comparison between the 3080 and 3090 in VR!!! Sorry but comparison between the 2080ti and 3090 is not news - it’s better than the 2080ti, we know that, but what we need to know is how much better is the 3090 over the 3080.
Very interesting, thanks.
3090 is a beast , shunt modded on water cooling will be interesting
Yes good stuff, If I just had a 3090 now :thinking:
I’m starting to love this guy - he’s going to put a kW of power through a 3090 once he gets a water block for it!!!
okay i did the 90hz test for you and the same settings as voodoo
Thankyou
Wonder why voodoo gets much worse results , his 2080ti stock settings results are about right
you seem to have a good 3090 there
