When I use 114hz, after a short while the right eye blacks out. It won’t return until I do reboot HMD from pitool, or hold power cycle the 8KX.
I’m on the 264 pitool beta and the beta firmware .294.
Is this a known issue? Any fixes?
Prior to switching to the beta firmware I had the 118hz option but it did not look right (some stutter and flicker). 114hz looks perfect, about as smooth as 120hz on index, but has this black eye issue.
I haven’t ever seen the issue happen at full res with 75hz.
I tried downgrading pitool to .262 as suggested (still with .294 firmware), and I had the same blank eye problem occur again. Has anyone who has seen the issue had luck in fixing it, and which versions of each did you switch to?
I’m having similar issues in 114 hz. It’s my left eye lens that blacks out, but the problem is the same.
Also, I’ve been having the headset just quit for a second, go black, and then come back but in a nonfunctional way- like the game screen is overlaid on the Steam VR screen. No way to get back to the game. It seems to happen mostly in Aces High. I have also had trouble with DCS- but my graphics card is underpowered for that game anyhow.
So far I’ve done this:
uninstalled ptools 284 and Pimax Experience.
set my Bios to normal clockspeed on my intel 9900k
reduced the video settings in the game (Aces High, DX 11
This issue needs to be addressed. It’s becoming a pain. Every time, you change to a new resolution in upscale mode, the right eye blanks out.
This happens in the same game or when start the next game.
Will also raise a ticket so that this gets some priority
