I have been using PiMax 4K on my desktop system for a while and am very happy with it.
Tomorrow I am going on a long trip so I decided to set it up on my laptop. SteamVR is not detecting the PiMax 4K. The HMD works ok with the PiMAX software in both Video and Pimax mode. I have tried bot PiMAX and video mode when starting SteamVR, I have also run PiMAX and Steam in administrator mode.
Please help.
Here is the system information and Steam Logs:
OS: Win 8.1 ver 6.3 Build 9600
Video: NVIDIA GTX-770 ver. 388.59
Pimax version 2.0.5.46
SteamVR Version 2017-12-04 (1512445023)
SteamVR System Report created Fri Dec 15 22:35:02 2017
SteamVR Version: 1512445023 SteamVR Date: 2017-12-04 Steam: Public Steam Branch: public Steam AppID: 250820 Tracking: No Driver OS: Windows 8.1 OS Version: 6.3.0.9600 Direct Mode Vendor: NVIDIA Direct Mode Version: 388.59 Admin: Yes AsyncReprojection: Enabled AllowReprojection: Yes (Good) ForceReprojection: No (Good) Performance drops: 0/1 0/2 0/3 0/4 0/0 Display Mode: Extended Display DeviceName: \\.\DISPLAY1 DeviceDirectMode: No DevicePrimary: Yes DeviceRect: 1920x1080 @ (0, 0) DeviceString: Intel(R) HD Graphics 4600 DeviceID: PCI\VEN_8086&DEV_0416&SUBSYS_FA771179&REV_06 DeviceKey: \Registry\Machine\System\CurrentControlSet\Control\Video\{2D2004D2-DC5F-4D3B-B27E-40607CDA0A9F}\0000 DeviceMonitorCount: 1 Monitor 0 DeviceName: \\.\DISPLAY1\Monitor0 Monitor 0 DeviceString: Generic PnP Monitor Monitor 0 DeviceID: MONITOR\AUO209D\{4d36e96e-e325-11ce-bfc1-08002be10318}\0003 Monitor 0 DeviceKey: \Registry\Machine\System\CurrentControlSet\Control\Class\{4d36e96e-e325-11ce-bfc1-08002be10318}\0003
DeviceName: \.\DISPLAY2
DevicePrimary: No
DeviceRect: 1920x1080 @ (1920, 0)
DeviceString: IntelÂź HD Graphics 4600
DeviceKey: \Registry\Machine\System\CurrentControlSet\Control\Video{2D2004D2-DC5F-4D3B-B27E-40607CDA0A9F}\0001
Monitor 0 DeviceName: \.\DISPLAY2\Monitor0
Monitor 0 DeviceID: MONITOR\SVR1019{4d36e96e-e325-11ce-bfc1-08002be10318}\0000
Monitor 0 DeviceKey: \Registry\Machine\System\CurrentControlSet\Control\Class{4d36e96e-e325-11ce-bfc1-
08002be10318}\0000
[HostController] Intel(R) 8 Series/C220 Series USB EHCI #2 - 8C2D Manufacturer: Intel, Provider: Microsoft, 6/21/2006, 6.3.9600.18814 Root Hub [Port1]: Generic USB Hub [Port1] [Port2] [Port3]: Intel(R) Wireless Bluetooth(R) 4.0 (VID:8087 PID:07DC) [Port4]: USB Composite Device (VID:04CA PID:701A) [Port5] [Port6] [Port2][HostController] USB xHCI Compliant Host Controller
Manufacturer: Generic USB xHCI Host Controller, Provider: Microsoft, 4/9/2015, 6.3.9600.17797
Root Hub
[Port1]: USB Input Device (VID:0483 PID:0021), Pimax VR, Inc., Rift P1, 10061164500112
[Port2]
[Port3]: Xbox 360 Wireless Receiver for Windows (VID:045E PID:0719), ©Microsoft, Xbox 360 Wireless
Receiver for Windows, E03F9310
[Port4]
[Port5]
[Port6]
[Port7]
[Port8]
[Port9]
[Port10]
[Port11]
[Port12]
[Port13]
[Port14]
[Port15]: (General Failure)
[Port16]
[Port17]
[Port18]
[Port19]: USB Mass Storage Device (VID:1058 PID:1140)
[HostController] Intel(R) 8 Series/C220 Series USB EHCI #1 - 8C26
Root Hub
[Port1]
[Port2]
[Port3]
[Port4]
[Port5]
[Port6]
[Port7]
[Port8]
[Port2]
=== vrserver.txt - C:/Program Files (x86)/Steam/logs
Fri Dec 15 2017 21:17:32.057 -
Fri Dec 15 2017 21:17:32.057 - Runtime path was D:\Games\SteamLibrary\steamapps\common\SteamVR. Setting it to D:
\Games\SteamLibrary\steamapps\common\SteamVR\ to match vrserver.exe
Fri Dec 15 2017 21:17:32.058 - Setting shared memory namespace to 9064
Fri Dec 15 2017 21:17:32.058 - VR server (v1512445023) starting up with config=C:\Program Files (x86)\Steam\config
Fri Dec 15 2017 21:17:32.058 - VRServer will wait for VRMonitor before exiting
Fri Dec 15 2017 21:17:32.062 - [Settings] Load Default Json Settings from D:\Games\SteamLibrary\steamapps\common
\SteamVR\resources\settings\default.vrsettings
\SteamVR\drivers\htc\resources\settings\default.vrsettings
\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
\SteamVR\drivers\null\resources\settings\default.vrsettings
Fri Dec 15 2017 21:17:32.063 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config
\steamvr.vrsettings
Fri Dec 15 2017 21:17:32.063 - Unable to read app config file from C:\Program Files (x86)\Steam\config
\appconfig.json. No applications will be available
Fri Dec 15 2017 21:17:32.067 - Add Json firmware manifest from {htc}/firmware/manifest.vrfirmware
Fri Dec 15 2017 21:17:32.067 - Add Json firmware manifest from {lighthouse}/firmware/manifest.vrfirmware
Fri Dec 15 2017 21:17:32.140 - New Connect message from D:\Games\SteamLibrary\steamapps\common\SteamVR\bin
\win32\vrmonitor.exe (VRApplication_VRMonitor) (Args: -nokillprocess) 8940
Fri Dec 15 2017 21:17:32.142 - Creating builtin app for D:\Games\SteamLibrary\steamapps\common\SteamVR\bin
Fri Dec 15 2017 21:17:32.142 - Setting app system.generated.vrmonitor.exe PID to 8940
Fri Dec 15 2017 21:17:32.147 - lighthouse: Attached HID Devices:
Fri Dec 15 2017 21:17:32.147 - lighthouse: No devices
Fri Dec 15 2017 21:17:32.147 - driver lighthouse implements interfaces IVRSettings_002
ITrackedDeviceServerDriver_005 IVRDisplayComponent_002 IVRDriverDirectModeComponent_004 IVRControllerComponent_001
IVRCameraComponent_002 IServerTrackedDeviceProvider_004 IVRWatchdogProvider_001 IVRVirtualDisplay_001
IVRDriverManager_001 IVRResources_001
Fri Dec 15 2017 21:17:32.147 - Loaded server driver lighthouse (IServerTrackedDeviceProvider_004) from D:\Games
\SteamLibrary\steamapps\common\SteamVR\drivers\lighthouse\bin\win64\driver_lighthouse.dll
Fri Dec 15 2017 21:17:32.147 - Driver lighthouse has no suitable devices.
Fri Dec 15 2017 21:17:32.148 - driver oculus implements interfaces IVRSettings_002 ITrackedDeviceServerDriver_005
IVRDisplayComponent_002 IVRDriverDirectModeComponent_004 IVRControllerComponent_001 IVRCameraComponent_002
IServerTrackedDeviceProvider_004 IVRWatchdogProvider_001 IVRVirtualDisplay_001 IVRDriverManager_001 IVRResources_001
Fri Dec 15 2017 21:17:32.148 - Loaded server driver oculus (IServerTrackedDeviceProvider_004) from D:\Games
\SteamLibrary\steamapps\common\SteamVR\drivers\oculus\bin\win64\driver_oculus.dll
Fri Dec 15 2017 21:17:32.148 - Driver oculus has no suitable devices.
Fri Dec 15 2017 21:17:32.149 - error VRInitError_Driver_RuntimeOutOfDate when initing driver oculus_legacy from D:
\Games\SteamLibrary\steamapps\common\SteamVR\drivers\oculus_legacy\bin\win64\driver_oculus_legacy.dll.
Fri Dec 15 2017 21:17:32.149 - Unable to load driver oculus_legacy because of error
VRInitError_Driver_RuntimeOutOfDate(204). Skipping.
Fri Dec 15 2017 21:17:32.149 - Not loading driver null because it is disabled in settings
Fri Dec 15 2017 21:17:32.149 - No connected devices found. Returning best error VRInitError_Init_HmdNotFound
Fri Dec 15 2017 21:17:32.149 - Allowing driver load failure VRInitError_Init_HmdNotFound for application vrmonitor
(8940) because it is vrmonitor
Fri Dec 15 2017 21:17:32.149 - Processing message VRMsg_Connect from vrmonitor (8940) took 0.00938 seconds
Fri Dec 15 2017 21:50:46.036 - Process vrmonitor (8940) has initiated a quit all
Fri Dec 15 2017 21:50:46.045 - Sending Quit event to process vrmonitor (8940)
Fri Dec 15 2017 21:50:46.046 - Closing pipe vrmonitor (8940) because it was broken from the other end
Fri Dec 15 2017 21:50:46.046 - Process vrmonitor (8940) disconnected (Thread(0x000000AADCD5FEC0/0x000)
Fri Dec 15 2017 21:50:46.056 - VR server shutting down
Fri Dec 15 2017 21:50:46.166 - Listener thread ending
Fri Dec 15 2017 21:50:58.834 -
Fri Dec 15 2017 21:50:58.834 - Runtime path was D:\Games\SteamLibrary\steamapps\common\SteamVR. Setting it to D:
Fri Dec 15 2017 21:50:58.836 - Setting shared memory namespace to 8112
Fri Dec 15 2017 21:50:58.837 - VR server (v1512445023) starting up with config=C:\Program Files (x86)\Steam\config
Fri Dec 15 2017 21:50:58.837 - VRServer will wait for VRMonitor before exiting
Fri Dec 15 2017 21:50:58.841 - [Settings] Load Default Json Settings from D:\Games\SteamLibrary\steamapps\common
Fri Dec 15 2017 21:50:58.842 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config
\steamvr.vrsettings
Fri Dec 15 2017 21:50:58.842 - Unable to read app config file from C:\Program Files (x86)\Steam\config
Fri Dec 15 2017 21:50:58.847 - Add Json firmware manifest from {htc}/firmware/manifest.vrfirmware
Fri Dec 15 2017 21:50:58.847 - Add Json firmware manifest from {lighthouse}/firmware/manifest.vrfirmware
Fri Dec 15 2017 21:50:58.912 - New Connect message from D:\Games\SteamLibrary\steamapps\common\SteamVR\bin
\win32\vrmonitor.exe (VRApplication_VRMonitor) (Args: -nokillprocess) 4468
Fri Dec 15 2017 21:50:58.914 - Creating builtin app for D:\Games\SteamLibrary\steamapps\common\SteamVR\bin
Fri Dec 15 2017 21:50:58.914 - Setting app system.generated.vrmonitor.exe PID to 4468
Fri Dec 15 2017 21:50:58.920 - lighthouse: Attached HID Devices:
Fri Dec 15 2017 21:50:58.920 - lighthouse: No devices
Fri Dec 15 2017 21:50:58.920 - driver lighthouse implements interfaces IVRSettings_002
Fri Dec 15 2017 21:50:58.920 - Loaded server driver lighthouse (IServerTrackedDeviceProvider_004) from D:\Games
Fri Dec 15 2017 21:50:58.920 - Driver lighthouse has no suitable devices.
Fri Dec 15 2017 21:50:58.921 - driver oculus implements interfaces IVRSettings_002 ITrackedDeviceServerDriver_005
Fri Dec 15 2017 21:50:58.921 - Loaded server driver oculus (IServerTrackedDeviceProvider_004) from D:\Games
Fri Dec 15 2017 21:50:58.921 - Driver oculus has no suitable devices.
Fri Dec 15 2017 21:50:58.923 - error VRInitError_Driver_RuntimeOutOfDate when initing driver oculus_legacy from D:
Fri Dec 15 2017 21:50:58.923 - Unable to load driver oculus_legacy because of error
Fri Dec 15 2017 21:50:58.923 - Not loading driver null because it is disabled in settings
Fri Dec 15 2017 21:50:58.923 - No connected devices found. Returning best error VRInitError_Init_HmdNotFound
Fri Dec 15 2017 21:50:58.923 - Allowing driver load failure VRInitError_Init_HmdNotFound for application vrmonitor
(4468) because it is vrmonitor
Fri Dec 15 2017 21:50:58.923 - Processing message VRMsg_Connect from vrmonitor (4468) took 0.0111 seconds
â vrserver.txt - C:/Program Files (x86)/Steam/logs
=== vrmonitor.txt - C:/Program Files (x86)/Steam/logs
Fri Dec 15 2017 21:50:58.670 -
Fri Dec 15 2017 21:50:58.670 - Unable to figure out runtime path from context. Not setting anything.
Fri Dec 15 2017 21:50:58.670 - vrmonitor starting up with config=C:\Program Files (x86)\Steam\config
Fri Dec 15 2017 21:50:58.670 - Runtime: D:\Games\SteamLibrary\steamapps\common\SteamVR
Fri Dec 15 2017 21:50:58.670 - Tools Path: D:\Games\SteamLibrary\steamapps\common\SteamVR\tools exists.
Fri Dec 15 2017 21:50:58.670 - Demo Path: D:\Games\SteamLibrary\steamapps\common\SteamVR\demo exists.
Fri Dec 15 2017 21:50:58.691 - AUDIO: Refreshing audio devices
Fri Dec 15 2017 21:50:58.709 - AUDIO: Detected 18 playback and 3 record devices
Fri Dec 15 2017 21:50:58.709 - Default Playback Audio Device: {0.0.0.00000000}.{4bf6cb4c-d2a0-43f2-8f30-
d8e608e4161d}
Fri Dec 15 2017 21:50:58.709 - -->Speakers (Conexant SmartAudio HD),0,Speakers,Conexant SmartAudio HD,
{0.0.0.00000000}.{4bf6cb4c-d2a0-43f2-8f30-d8e608e4161d}
Fri Dec 15 2017 21:50:58.709 - PIMAX P1 (IntelÂź Display Audio),0,PIMAX P1,IntelÂź Display Audio,
{0.0.0.00000000}.{abf72bd5-84a5-4fbd-afc0-c36076a1c045}
Fri Dec 15 2017 21:50:58.709 - Default Record Audio Device: {0.0.1.00000000}.{12efd62c-4133-4cf3-93cf-4eb1739964f8}
Fri Dec 15 2017 21:50:58.709 - -->Microphone (Conexant SmartAudio HD),0,Microphone,Conexant SmartAudio HD,
Fri Dec 15 2017 21:50:58.712 - [System] Prepare operating system environment
Fri Dec 15 2017 21:50:58.712 - [System] Setting power settings to minimum power savings.
Fri Dec 15 2017 21:50:58.737 - [System] Detected first setup.
Fri Dec 15 2017 21:50:58.737 - [Settings] Load Default Json Settings from D:\Games\SteamLibrary\steamapps\common
Fri Dec 15 2017 21:50:58.738 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config
\steamvr.vrsettings
Fri Dec 15 2017 21:50:58.739 - Enabling direct mode for NVIDIA [Vid=0xD222 Pid=0xAA01]âŠ
Fri Dec 15 2017 21:50:58.739 - Success!
Fri Dec 15 2017 21:50:58.741 - [System] Transition from âOffâ to âStartingâ.
Fri Dec 15 2017 21:50:58.762 - [System] Runtime: 1512445023 250820 SteamVR
Fri Dec 15 2017 21:50:58.924 - VR_Init failed with Hmd Not Found (108)
Fri Dec 15 2017 21:50:58.925 - [Steam] Attempt to connect to Steam
Fri Dec 15 2017 21:50:58.925 - Add Json firmware manifest from {htc}/firmware/manifest.vrfirmware
Fri Dec 15 2017 21:50:58.925 - Add Json firmware manifest from {lighthouse}/firmware/manifest.vrfirmware
Fri Dec 15 2017 21:50:58.926 - [Bluetooth] Bluetooth init postponed
Fri Dec 15 2017 21:50:58.926 - [Audio] Audio init
Fri Dec 15 2017 21:50:58.926 - [System] Check for dismissable warnings at init.
Fri Dec 15 2017 21:50:58.926 - [System] No warnings about display in Extended Mode at first setup.
Fri Dec 15 2017 21:50:58.939 - Large number of events this frame caused the poll loop to exit without draining
Fri Dec 15 2017 21:50:58.955 - Large number of events this frame caused the poll loop to exit without draining
Fri Dec 15 2017 21:50:58.983 - Large number of events this frame caused the poll loop to exit without draining
Fri Dec 15 2017 21:50:58.995 - [Steam] Connected to Steam in 0.07 seconds.
Fri Dec 15 2017 21:51:03.928 - [System] Runtime: 1512445023 250820 SteamVR
Fri Dec 15 2017 21:51:03.929 - [Steam] Connect to Steam finished: check for dismissable warnings
Fri Dec 15 2017 21:51:03.929 - Large number of events this frame caused the poll loop to exit without draining
Fri Dec 15 2017 21:51:03.931 - [Status] Graphics driver version is 388.59.
Fri Dec 15 2017 21:51:03.935 - [Status Alert] Headset not detected (108)
Fri Dec 15 2017 21:51:03.937 - [System] Transition from âStartingâ to âConnectingâ.
Fri Dec 15 2017 21:51:04.308 - Large number of events this frame caused the poll loop to exit without draining
Fri Dec 15 2017 21:51:04.309 - [System] Transition from âConnectingâ to âNot Readyâ.
Fri Dec 15 2017 21:51:08.702 - [System] System is running for 10 seconds.
Fri Dec 15 2017 21:51:08.702 - [System] Check for dismissable warnings at startup.
Fri Dec 15 2017 21:51:08.702 - [System] No warnings about missed frames at first setup.
Fri Dec 15 2017 22:08:39.982 - AUDIO: AudioDeviceChangeNotice (noting refresh): 4, device = {0.0.0.00000000}.
Fri Dec 15 2017 22:08:39.982 - AUDIO: OnDefaultDeviceChanged: flow = eRender, role = eConsole, device =
Fri Dec 15 2017 22:08:39.982 - AUDIO: OnDefaultDeviceChanged: flow = eRender, role = eMultimedia, device =
Fri Dec 15 2017 22:08:42.008 - AUDIO: AudioDeviceChangeNotice (noting refresh): 2, device = {0.0.0.00000000}.
Fri Dec 15 2017 22:08:42.008 - AUDIO: OnDeviceStateChanged: DEVICE_STATE_NOTPRESENT (0x00000004), device =
Fri Dec 15 2017 22:08:42.008 - AUDIO: Refreshing audio devices
Fri Dec 15 2017 22:08:42.031 - AUDIO: Detected 18 playback and 3 record devices
Fri Dec 15 2017 22:16:53.854 - AUDIO: AudioDeviceChangeNotice (noting refresh): 2, device = {0.0.0.00000000}.
Fri Dec 15 2017 22:16:55.157 - AUDIO: OnDeviceStateChanged: DEVICE_STATE_ACTIVE (0x00000001), device =
Fri Dec 15 2017 22:16:55.162 - AUDIO: AudioDeviceChangeNotice (noting refresh): 2, device = {0.0.0.00000000}.
Fri Dec 15 2017 22:16:55.162 - AUDIO: OnDeviceStateChanged: DEVICE_STATE_NOTPRESENT (0x00000004), device =
Fri Dec 15 2017 22:16:55.171 - AUDIO: Refreshing audio devices
Fri Dec 15 2017 22:16:55.190 - AUDIO: Detected 18 playback and 3 record devices
Fri Dec 15 2017 22:16:57.920 - AUDIO: AudioDeviceChangeNotice (noting refresh): 4, device = {0.0.0.00000000}.
Fri Dec 15 2017 22:16:57.920 - AUDIO: OnDefaultDeviceChanged: flow = eRender, role = eConsole, device =
Fri Dec 15 2017 22:16:57.920 - AUDIO: OnDefaultDeviceChanged: flow = eRender, role = eMultimedia, device =
Fri Dec 15 2017 22:16:58.817 - AUDIO: AudioDeviceChangeNotice (noting refresh): 2, device = {0.0.0.00000000}.
Fri Dec 15 2017 22:16:58.817 - AUDIO: OnDeviceStateChanged: DEVICE_STATE_ACTIVE (0x00000001), device =
Fri Dec 15 2017 22:16:58.817 - AUDIO: Refreshing audio devices
Fri Dec 15 2017 22:16:58.840 - AUDIO: Detected 18 playback and 3 record devices
Fri Dec 15 2017 22:17:34.151 - AUDIO: AudioDeviceChangeNotice (noting refresh): 2, device = {0.0.0.00000000}.
Fri Dec 15 2017 22:17:34.356 - AUDIO: OnDeviceStateChanged: DEVICE_STATE_NOTPRESENT (0x00000004), device =
Fri Dec 15 2017 22:17:34.375 - AUDIO: Refreshing audio devices
Fri Dec 15 2017 22:17:34.396 - AUDIO: Detected 18 playback and 3 record devices
Fri Dec 15 2017 22:17:36.988 - AUDIO: AudioDeviceChangeNotice (noting refresh): 4, device = {0.0.0.00000000}.
Fri Dec 15 2017 22:17:36.988 - AUDIO: OnDefaultDeviceChanged: flow = eRender, role = eConsole, device =
Fri Dec 15 2017 22:17:36.989 - AUDIO: AudioDeviceChangeNotice (noting refresh): 4, device = {0.0.0.00000000}.
Fri Dec 15 2017 22:17:36.989 - AUDIO: OnDefaultDeviceChanged: flow = eRender, role = eMultimedia, device =
Fri Dec 15 2017 22:17:37.413 - AUDIO: AudioDeviceChangeNotice (noting refresh): 2, device = {0.0.0.00000000}.
Fri Dec 15 2017 22:17:37.413 - AUDIO: OnDeviceStateChanged: DEVICE_STATE_ACTIVE (0x00000001), device =
Fri Dec 15 2017 22:17:37.413 - AUDIO: Refreshing audio devices
Fri Dec 15 2017 22:17:37.440 - AUDIO: Detected 18 playback and 3 record devices
Fri Dec 15 2017 22:35:02.160 - Open URL vrmonitor://open/systemreport
Fri Dec 15 2017 22:35:02.402 - [System Report] Discover USB Topology: Took 0.23 seconds
Fri Dec 15 2017 22:35:03.012 - [System Report] Iterate USB Topology: Took 0.61 seconds
â vrmonitor.txt - C:/Program Files (x86)/Steam/logs
=== vrclient_vrmonitor.txt - C:/Program Files (x86)/Steam/logs
Fri Dec 15 2017 21:50:58.801 - vrclient startup with PID=4468, type=VRApplication_VRMonitor, config=C:\Program Files
(x86)\Steam\config
Fri Dec 15 2017 21:50:58.802 - [Settings] Load Default Json Settings from D:\Games\SteamLibrary\steamapps\common
Fri Dec 15 2017 21:50:58.803 - [Settings] Load Default Json Settings from D:\Games\SteamLibrary\steamapps\common
Fri Dec 15 2017 21:50:58.804 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config
\steamvr.vrsettings
Fri Dec 15 2017 21:50:58.806 - Starting vrserver process: D:\Games\SteamLibrary\steamapps\common\SteamVR\bin
\win64\vrserver.exe
Fri Dec 15 2017 21:50:58.923 - Received success response from vrserver connect
Fri Dec 15 2017 21:50:58.923 - [Chaperone] No chaperone data. C:\Program Files (x86)\Steam\config
\chaperone_info.vrchap does not exist
Fri Dec 15 2017 21:50:58.998 - Starting vrcompositor process: D:\Games\SteamLibrary\steamapps\common\SteamVR\bin
\win32\vrcompositor.exe
Fri Dec 15 2017 21:51:03.928 - Giving up compositor connection after 50 attempts
Fri Dec 15 2017 22:34:48.203 - Starting vrcompositor process: D:\Games\SteamLibrary\steamapps\common\SteamVR\bin
â vrclient_vrmonitor.txt - C:/Program Files (x86)/Steam/logs
=== vrcompositor.txt - C:/Program Files (x86)/Steam/logs
Fri Dec 15 2017 22:34:48.226 - VR compositor (v1512445023) starting up
Fri Dec 15 2017 22:34:48.226 - RuntimePath : D:\Games\SteamLibrary\steamapps\common\SteamVR
Fri Dec 15 2017 22:34:48.290 - Failed to start compositor: VRInitError_Init_HmdNotFoundPresenceFailed
â vrcompositor.txt - C:/Program Files (x86)/Steam/logs
=== vrclient_vrcompositor.txt - C:/Program Files (x86)/Steam/logs
Fri Dec 15 2017 21:14:49.776 - vrclient startup with PID=1568, type=VRApplication_Scene, config=C:\Program Files
(x86)\Steam\config
Fri Dec 15 2017 21:14:49.778 - [Settings] Load Default Json Settings from D:\Games\SteamLibrary\steamapps\common
Fri Dec 15 2017 21:14:49.779 - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config
\steamvr.vrsettings
Fri Dec 15 2017 21:14:49.780 - Returning HmdNotFound because the client-side presence check failed.
â vrclient_steamvr_room_setup.txt - C:/Program Files (x86)/Steam/logs
C:/Program Files (x86)/Steam/logs/vrclient_steamvr_tutorial.txt is not available.
Runtime Directory: D:\Games\SteamLibrary\steamapps\common\SteamVR\ Log Directory: C:\Program Files (x86)\Steam\logs Config Directory: C:\Program Files (x86)\Steam\config { "steamvr" : { "enableHomeApp" : false } } Play Area Size: None found Collision Bounds: None found
