Okay not good for sure. Hopefully can get this fixed asap. Welcome to the open Beta.
Have suggested implementing a roll back option when they have time.
Voodoo had the same problem and a Pimax engineer had to remote connect to his computer to fix it. If a Pimax engineer could connect with me, that would be greatly appreciated.
Added a couple of pokes to your post. From my understanding Doman was one of the techs that assisted some users with this.
Changed the PiServiceLauncher to run automatically and the issue is resolved.
I donāt think thereās any need to be nasty about it, itās just a mistake. And no doubt will be fixed soon, getting cutting edge tech like this comes with itās teething problems after all.
Personally Iām in the āif itās not broken donāt try to fix itā persuasion, so long as everything is working as I like it I wonāt ever upgrade anything unless I specifically require a feature, that goes for bios and software, this often makes life simpler as you sit back and read threads like this, people who instantly install new updates always run the risk of beta testing for the rest of us lol. So thanks for that. Plus now Pimax is in the wild and lots of VR channels are receiving them so your channel isnāt maybe as important as you seem to think.
Please send me ID&password of teamviewer when you are available.
I would like to take a check.
Thanks! Or could you simply let us know what you actually do on these teamviewer sessions? Like what did you do on voodoos computer for example? Cuz then probably people who come across this problem can simply do it themselves wihout having to rely on a one on one session.
There was a software tracking issue on voodoos computer.But Iām not sure if you have the same issue.So I have to check about it.
just move your headset around all axis a few timesā¦ what a beta tester you are
had it a few times but not related to any updates.
This could be kinda awkward, let the Pimax team browse the contents of your PC or donāt have tracking
Time to hide the porn?
Glad I have a dedicated VR box!!!
Got it.Will reply you soon.
@Doman.Chen , let him first move his headset around all axes a few timesā¦ I am pretty sure it will fix itā¦
Thank you.I think he have tried that already.
So remote access is not necessary?
@Doman.Chen , Heās a member of my forum and sent you an email, but he didnāt get an answer. Heās eagerly waiting for you. Pls give him quick help, too.
I can check about it if you are available.
The team will reply him soon.
I sent you the ID and pwd, I am available now.
