I was a microsoft certified system engineer, rule #1 never install any update if youâre not 110% sure it is tested and fine, let other people find the bugs, keep your system safe, and wait for the real correct stable update before messing with the client server
I also have these tracking issues and the fix by doman.chen over team viewer did help but I still have issues with tracking. Often the headset isnât tracked, the controllers are far away but tracking. It takes several reboots and setup of roomscale again, also a little prayer and maybe it works for a game session once in a while.
I had the same problem, but I changed the PiServiceLauncher to autorun and turned on base stations and pimax before turning on PC. The problem was resolved.
I had no troubles at all on 95 for a week. then two times no tracking of the headset and basestations ânot trackedâ also in pitool. I switched one of the vive wands on and the basestations responded and wand and stations were tracked but still not the headset.
in both cases I just moved the headset around its axes a few times, like calibrating it, and after a few seconds doing that it started working.
