Just setting up my 5k+ . Can anyone tell how to start Oculus games? When I try to start from pitool nothing happens and it’s the same with steam games but I can start steam games from steam .
Did you input oculus games to pitool interface?
They just appeared when I installed pitools . Do I still need to manually import them ?
No need,just open them.
When I click on them nothing happens .
Did you trun on steamvr when you run oculus games?
Yes I have steam vr running
Pitool says I need to launch Oculus services
Yes,please launch oculus sevices first and turn off steamvr before you run oculus games.
Oculus service and steam Vr are running but still games won’t start
Did you update to latest pitool version?
Yes I have installed the latest version
As I said I can run steam games but I have to start them from steam
All my oculus games show up in pitool but they won’t start .
I will keep trying different things . My machine is way over due for a formatt and fresh windows 10 install . Thanks for your very fast response to my questions .
Is your oculus games run normal before?
Yes they all ran fine . Don’t worry too much just yet . I will keep trying to figure it out . I think it might be a problem at my end .
Sounds good,please export log and PM me,I will ask our engineer to check together,thanks.
I will . Thanks for your help Doman
Is this normal ? When I am in dark areas they get washed out by this yellow glow that makes everything hazy . @spamenigma
