I hope the following picture can solve your doubts. Thank you
Hi Matthew,
The response is very much appreciated - thank you! However it does not answer all the questions. Ones in bold below remain a mystery.
Thanks!
What is refresh rate?
What is subpixel pattern?
How does SDE compare to 5k+, Vive Pro?
Has ghosting issue been eliminated?
Will Brainwarp work with this headset (assuming it ever works at all as we have precious little from @deletedpimaxrep1 or @PimaxVR about this despite many of us asking many times)
I canāt answer all those questions howeverā¦
The refresh rate is listed in the specs provided by Matthewā¦
I spoke with Xunshu and she told me that the BE model will use the same drivers that the 5K+ and 8K will use including BrainWarp when that (and if) that ever becomes available.
Pimax has said there will be more SDE with the BE model compared to the 5K+ and 8K
Subpixel and ghostingā¦ I donāt know. However, if the BE model has ghosting now (I tried the BE model myself but was limited to the LEAP demo software. Hard to see ghosting with that demo) ā¦ I seriously doubt they will fix thatā¦ even if they said they will in the future. I say that from experience of being a Pimax 4K owner.
Thanksā¦ This is the closest to answers I have seen!
You need to fix your pre order page, the 5K+ is listed as OLED.
Thank you for your warning, we will update it right now. Thank you
Thank you for your answer but please @Matthew.Xu (or anyone who tried them) correct me if Iām wrong with this;
Only in terms of SDE and black levels:
The 5k+ is equal to the Oculus Go
The 5kBE is equal to Odyssey/Vive pro
Hi @Matthew.Xu,
Will testers be receiving the 5KBE? If so when?
Thanks
@SweViver @mixedrealityTV @VoodooDE
I need to confirm this question and reply to you later. Thank you
I appreciate your response. Thank you.
@Matthew.Xu When will you provide the official comparison, and ship units of the BE version to reviewers as @deletedpimaxrep1 posted 15 days ago?
Thank you
I will confirm this matter and reply to you tomorrow. Thank you.
Great, thank you for your support
Yep, Iām sorry I didnāt replyā¦ there are some things that need to be confirmed.
So, I will reply asap. Thank you
