So what the deal with prescription adapter?
But that one you linked would block a significant portion of the display. The whole point of Pimax releasing an official lens adapter is to have one that fits the entire display, so we need to find a way to get a lens that fits that.
I know it was just an example of what possible.
It doesnât block more than glasses frames.
Thereâs also nyajigon22âs frame that uses ZENNI lenses. More informations here:
https://community.openmr.ai/t/pimax-5k-8k-prescription-lens-adapter/19796
But thatâs the whole point. If it blocks the same as if wearing glasses, might as well just wear glasses. Pimaxâ official adapter is supposed to allow lenses that cover the entire field of view without anything blocking at all, as well as allowing physical IPD adjustment to still work. Thus Iâm asking how are we supposed to have lenses made that fit it (and where we can download the 3D print). Pretty sure Zenni Optical doesnât make glasses with lenses like this
This! Pimax has not been very clear or concise on the whole prescription lens subject.
Hi !
I use google translation
Regarding the accessories sent on request to the backers, it only concerns the fan OR other things too?
I would like to have the fan and the VR custom prescription frame.
how and where do you ask to receive this?
Still nothing about the prescription adapters
This one looks pretty good. I noticed you were in the discussion. How is it? Are you currently using it or you went back to glasses.
I donât use glasses anymore, not because they donât fit but because I always had to adjust them inside ^^
Iâve used my mod for months, itâs pretty good but my eyelashs tended to touch prescription lenses (due to inverse curve).
Now (to be accurate: untill I sent my Pimax 3 weeks ago for RMA), I use nyajigon22âs. Once I edited his model to fit with my IPD itâs perfect and I donât need to add foam space anymore (Iâm using Vive wide foam)
What ipd do you have? Mines 68 ipd. You think the 65 version is best for me? Pretty sure i can use the software ipd to change it to 68.
There may be some updates after the upgrade plan.
Ipd 72. If 65 version isnât good for you, send me a private message and Iâll upload for you my 70 mod.
What infil% thickess and material did you use?
After the upgrade plan? Im starting to believe there wont be any lens support.
I donât remember settings used but youâll need supports. PLA is fine
Thanks i just ordered the glasses and got the frame ready.
