OMG it Works
I just want again to thank you and @SweViver so much for your hard work! I guess you two spend so many hours on troubleshooting the last days for this update. And i should probably also thank @Smiley for volunteering!
I’m so happy right now, i could hug the whole world…
I definitely want to thank @arminelec and @SweViver for troubleshooting with me and figuring out what was happening. Everything is working as expected and I am thoroughly enjoying this new experience. They have definitely renewed my faith in purchasing this headset.
Soon we will try to obtain a Microsoft trusted-installer certification for our PE installer (just like Pimax did with PiTool installer). Until thats done, the warning popup upon starting the installer will be there, and you have to manually allow Windows to ignore the warning and let it run.
Hello Martin oh, well yeah that’s usually what you can do with that but mine’s not letting me check that little box off to do it manually it just won’t straight up let me open it
Try to click on start and type in “Potentially Unwanted Applications” and hit enter. A Window should open where you want to disable the third entry. I don’t know how it’s named in english, but it should be something like “block unwanted apps”. After that the Run anyway button should appear in the window sweviver posted above. Just to be safe you should probably enable this setting again.
If it doesn’t work you could try to also disable the first entry (probably called “check apps and files”).
