Heres the thing. If the userSettingsPVR.json isn’t created the application will definitely not work. So we have to investigate why the file isn’t created.
Are you running any antivirus software
The mouse and UltraLeap is no problem. Its just that the application doesn’t initiate with a json config is not being able to be created.
I don’t know what’s wrong, but I think that PE can be started by completely erasing
the pimax software and config settings and reinstalling.
Only uninstalling the pimax software doesn’t seem to solve it.
The following folders also had to be deleted.
Of course, the settings will also disappear
Ok, to see if this changes anything, could you create a userSettingsPVR.json file (inside C:\Users\ SweViver \AppData\LocalLow\Pimax\PVRHome) including this:
NOTE: Change “SweViver” to your username both in link above and in the config file below:
I just removed the PiTool software, deleted all of those folders, rebooted, re-installed version 264 of PiTool, reinstalled the PE, rebooted again. Still seeing the same thing. I also put that created userSettings PVRfile (just in case), and it didn’t make a difference. The userSettingsPVR file isn’t being created for me.
@SweViverMaybe i can provide some additional info for this problem. As far as i’m concerned what no one mentioned is, when i turn my head to my right or left, my left eye gets zoomed in pretty hard wich caused instantly eyestrain. Never happens on the right eye no matter in wich direction i look.
In my Player.log there are these two lines wich doesn’t seem right:
WARNING: Shader Unsupported: 'Toon/Basic Outline' - All passes removed
WARNING: Shader Did you use #pragma only_renderers and omit this platform?
And in the output_log.txt are these:
Fallback handler could not load library C:/Program Files/Pimax/PVRHome/PVRHome_Data/Mono/libPVRClient32.dll
Fallback handler could not load library C:/Program Files/Pimax/PVRHome/PVRHome_Data/Mono/.\libPVRClient32.dll
Setting up 4 worker threads for Enlighten.
Thread -> id: 30e0 -> priority: 1
Thread -> id: 74c -> priority: 1
Thread -> id: 1504 -> priority: 1
Thread -> id: 3174 -> priority: 1
Leap Service not connected; attempting to reconnect for try 1/5...
(Filename: C:\buildslave\unity\build\Runtime/Export/Debug.bindings.h Line: 43)
Leap Service not connected; attempting to reconnect for try 2/5...
Leap Service not connected; attempting to reconnect for try 3/5...
Leap Service not connected; attempting to reconnect for try 4/5...
Leap Service not connected; attempting to reconnect for try 5/5...
When i looked up for these “libPVRClient32” files, i noticed that i don’t even have the “Mono” folder in “C:/Program Files/Pimax/PVRHome/PVRHome_Data/”.
I also deleted all of the mentioned folders from the temporary fix and tried to just install “PiToolSetup_1.0.1.264” and move the content from the “PVRHome_v0.50.rar” you provided in the right directory and manually creating an (edited) “userSettingsPVR.json” file but it doesn’t seem to make any difference.
PS: If you need the whole log files just let me know, but the rest did look normal to me.
I still have the same issue too, also deleted all files and reinstall PiTools. I also notice that as soon as I click on PCRHome.exe my mouse freezes until i click the Windows key.
Thank you for taking time and pointing these out. The shader warning in this build is alright. But I’ll fix the issue causing this anyway.
I’ll try to reproduce and fix the issue with sudden zoom on the left eye.
The issue with DLLs in the Mono folder, only happens on some PCs. We have tried numerous ways to reproduce it but have had no luck. We’ll keep on trying. It might be related to the issue where some users do not have their json file created. Might be, not sure yet.
Just to be clear on my side, after deleting all files and reisntalling the PiTool vesion 1.0.2.xxx (which bundles the new PVRHome.exe), was your userSettingsPVR.json file also not created, yet the mouse was locked at the center?
I ask, since in our latest 0.50 build, the mouse should only get locked, when user has already interacted in VR, using either a controller to enable the mouse, or updating the json file to make it happen.
I noticed my mouse being locked as well. I didn’t mention it earlier because I thought it was just a coincidence. I just got used to hitting the windows key whenever I needed to use my mouse. And yes, the json file will not create itself for me.
Thanks! your confirmation helps. We are trying to find out whether it could be caused by certain configurations on user’s Windows or caused by another process. I could assume, but it is better to ask: which version of Windows do you use? 32-bit or 64-bit?
