My knuckles are arriving in 2 hours is there any work arounda or anything to get them working as have 3 lighthouses and knuckles and cant even use any of it as my wands wont even track on the new lighthouses
That not sure wands are different & have thrir own directory.
Look for resource files (pics of wands) you might be able to load images & fix. But be sure to create a zipped backup. Games might also use their own resource files for wands.
my controllers have arrived i can pair them in pitools but steamvr sees them as the vive controllers, is that the problem that will be fixed with the incoming fix or is there something else, do i have to install drivers in steamvr
This not sure as Cas & Chary had them I believe showing as Index Controllers in SteamVR Window.
If you mean in a particular game? If the game is older it will likely show wands instead of Index Controllers. TownVR? I think was the title of the game in Cas & Chary’s livestream; that game I believe has direct index support.
yes, with the driver fix knuckles use the correct shape model even in SteamVR Home. The only missing image is the one in the SteamVR status window, but it’s not really an issue
It’s PiTool that sends the controller shape to SteamVR Home, but the model is taken from the old drivers folder. With the fix it works properly, the new PiTools will look for the model in the new location, I guess
