Could be for sure. Just figured the steamvr beta might also have it updated to procure controller pics.
My XBox controllers shows as Vive wands in Steamvr home. As does the Razer Hydra. But with Index controllers showing as Index demonstrates. Hydra driver could have had Hydra models to show instead of wands. (Would make it easier to use them for sure) lol
thanks working now cheers
Index controllers work fine once you download the drivers for them.
Yep it was just Advanced/early beta owners ran into troubles with pimax use due to name & location change.
Any receiving via pre order controllers will work fine on install. No beta baggage. Fixes only needed for pre release owners.
Thatās confirmed by someone, or is a theory?
Cas & Charyās Livestream. Thatās all they did.
Cas & Chary owned the Knuckles for a long time, an EV3 unofficially given by some dev
So ive done the fix but getting no controllers in the hmd there tracking but no image also only 1 lighthouse showing up in steam please help lol
@Heliosurge the first retail Index Controller are delivered today, I would wait for the new users to confirm, and not a sort of āUh? I donāt know what I did, but it worksā
Well itās there. Problem occured due to beta name change from VRknuckles to index controllers.
Openvrpaths.vrpath file identifies controller link to pitool directory
Your fix will work for pre owners yes. New owners shouldnāt need it as Cas & Chary didnāt use your fix as they stated.
Your fix puts driver location back to where it was.
We have someone going to confirm what Cas & Chary already demonstrated in livestream.
Well, I think the problem was due to a file location change, hardcoded in PiTool, but thatās a theory too. Iām waiting for the scientific confirmation so that I can abandon all the theories
Cas & Chary are not demostrating Index Controller, but pre-owned Knuckles EV3, I guess
Nobody owned Index Controller until today
Itās not hard coded. Check %Appdata\Local\openvr
File. Itās there as is my Razer Hydra is hooked to SteamVRSupport directory in pimax pitool directory. Canāt be hard coded either as folks install to different drives.
No itās still the Index Controller. Otherwise your fix will only work on the Ev3 controller as you said folks are only receiving index controllers today.
Uh? And how did they get the Index Controllers in advance? I own three pairs of EV3s and a couple of DVs, but Valve said they wouldnāt send the Index Controllers
but, in any case, Iāll wait for a real confirmation. We wonāt have to wait too long, right?
Iāll be happy if new users wonāt need any fixes, but I donāt make any claims without solid confirmation
Then your fix works only for ev3 controllers. Ev3 is just the unfinished name. There might be slight changes. To consumer release.
Easy for you to check & see itās not jard coded in pitool by looking at the file I mentioned. It simply was looking for the VRKnuckles Driver which is now named & located in a different location.
Why it was broken for you & others & worked fine for Cas & Chary whom didnāt have old baggage from beta knuckles.
Sdubbin I believe had controllers working but not represented by index pics in steamvr home. Until he applied your fix. Suggesting Steamvr Home grabs controller pics in program. Hence why your fix fixed pic in Home.
DV is the last developer versionā¦ but Iām not saying that controllers are different, Iām saying that the scenario is different.
Cas & Charry donāt represent the scenario that interests me, users who receive Index Controller starting from today
Iā m not controversial, Iām just a technician, and for a technician one thing works when it works.
So, Iām waiting for real buyer confirmation, and Iāll be happy if youāre right.
nope, this doesnāt demonstrate what you say, but you need programming knowledge to understand what I mean
