Nope. I don’t think so but I would just install it anyway.
It’s supposed to be working on the latest Nvidia driver, but we (the public) haven’t seen the latest firmware update yet. The 90Hz beta firmware doesn’t work for me on latest Nvidia driver so I’m guessing/hoping I need an updated firmware (which isn’t out yet - there’s no firmware available when I check in .271).
It’s hard to tell at a glance what Pimax is supporting, and I’m always reluctant to just ‘install the latest’ without feedback, because it can break a lot more than it improves
Later ones are apparently delivered via ‘cloud’ - meaning? From PE Cloud profile or something?
I manually downloaded PT 271 from here and installed it, and it tells me there’s no FW update for 255. Which I assume is wrong. Is there a link to manually download a later one?
Aaaaand…I see I have to set PE as ‘Home’…now PT is downloading PE ~247Mb…is this actually the best way to update and install PE now?
OK, tried out.
RTX 3090, Nvidia driver version is 466.63
Pitool updated to V1.0.1.217. FW is x.298. (the 90Hz beta)
Set Panel Mode to native, set to 90 Hz.
Screen blacked on HUD.
no success.
Pitool “Restart Service” caused an error
sorry for message in German.
What is expected to be checked from our side as customers and testers?
By the way, tried upscaling with 114Hz, worked, but I am not convinced, SteamHome screen text is a little bit blurry, so useful for certain applications, but not in general.
I can confirm AMD 6900XT @ 90hz 90 FPS on 8Kx is working, and has been for weeks.
Look great! feels great!
It is not all good. There is a problem (double vision) with SS and if I drop below Hz then I get double vision (in each eye).
e.g. 90hz hit 85fps or 75Hz hit 70fps
It is like having two pictures on top of each other, off set.
i.e. The original image and the fill in replacement image on screen at the same time and not aligned. This is in either eye, or both or one at a time.
Two tickets written, pimax seam to be ignoring it.
