I’m lost, what exactly is changed about the IPD adjustment?
I’ve installed the new pitool for sure, I’ve seeing the green Pi logo instead of the old white logo.
Is there a new setting for ipd or something? I’m not sure what I am looking for here.
NEW BETA Pitool designed to resolve issues with IPD adjustment. This new Pitool allows much more detailed adjustment of IPD and allows EACH EYE to be individually adjusted.
If you are having any issues with picture focus or clarity this Pitool can resolve these issues and we encourage you to give it a try. You can download it here with this link:
Of course we are always looking for ways to improve and if you have suggestions for further enhancements to Pitool please let us know via your feedback to the community and we will report your outcome to the R&D team!
Ah ok, so previously it was seperate for vertical and horizontal offset whereas now those settings can also be altered per eye?
Did that make any meaningful difference?
@Akuma540 described that previously he used an offset of +3 and now needs no offset, which leads me to believe that the changes might be a bit deeper than simply an added functionality.
I was under the impression that any new version of PE woud first be announced by @SweViver but maybe that has changed. Will have to check this out over the weekend.
I’ll check the version later too unless someone beats me to it.
EDIT: @twack3r. I was wrong. It actually overwrites Pimax Experience with the default still picture thing.
FYI: @SweViver. Installing the updated PiTool overwrites the PE install so You have to re-install it again. That can’t be intended, right? PiTool should probably check if PE is installed and if it is use it and if not, default to the fixed image…?
I seemed to have my 8KX dialed in very nicely the last few days for the first time in a while (mostly due to face foam symmetry), hopefully this new Pitool doesn’t mess it up. More options the better I think.
