Greetings 4k users.
I have an interesting issue that I can’t seem to get around. When I connect my 4k HMD, PiPlay (or the new one), sees the USB and HDMI as connected, but wont show the device farther than that. AS in, it will not allow me to change from video mode to PiMax(direct) mode, because it is not fully identified, so I don’t get the option to switch because PimAx can’t “see” it properly.
I had this happen once before, and disconnecting it for an hour, correct it, or got it out of its fit…
That isnt working this time.
To try and kick it into gear, I ran thru the complete reset (all 3 buttons, then leave off power, then vol down, etc). Getting it into firmware mode, but I cant recall if there is another way to re-set it.
I am getting the same behavior on two separate computers…so its something with the HMD being stuck, and not software. I have tried 3 different versions of PiMax and PiPlay on both machines, with the same results and no change.
Any suggestion to re-set the HMD?
The last time I used the HMD, it was working just fine, and I was racing in RF2 with no issues, so this is really weird. I don’t keep the device connected all the time, but have had weird issues with it getting stuck in certain modes before. All of which I have been able to recover from.
Any suggestions are welcomes. Also, I ran thru all the relevant things I found on the fourm, but its still not properly identified like it used to be. I am sure its something simple, but I cant seem to get it going.
In device manager, it shows as a generic plug-n-play screen, and I am almost sure it used to show as a RIFT… I can install Oculus home, but dont want to just to trick a driver.
Thanks!!
