I would like to help out as well!
2700x 2080ti. 16gb ddr memory.
8kx to arrive within 48hrsđ
Sounds great, thanks man! Added you now!
iâll help out if there are still any slots!
Excellent! I love what Iâm seeing so far. The only thing I can think of asking for so far is a âPimax boundaryâ that can be used for Oculus games! Even if it simply copies the SteamVR one (if thatâs even possible) that would be excellent. It looks to me like everything that is configurable in PiTool is working perfectly. I think I pushed just about every button
9 posts were split to a new topic: Shipping Discussion (upgraders vs pre-orders)
Letâs try not to clutter this one thread as itâs used by SweViver to keep track of Pimax Experience beta testersâŚ
I would like to help, please Sweviver, count me in
Intel 6700k RTX2080 32gb ddr memory.
8kx arrive tomorow within 6H00 pm, and very excited !
Hi SweViver, please add me as well.
I got 8KX two days ago and was not satisfied - the image is not sharp as I expected. On this forum I read everything about steamvr.vrsettings. I very carefully updated the config file but image is still blurry. In Potato FOV the sharpness is amazing. I am looking forward to see how your app will handle it.
Unfortunately, getting it right is tricky. It sounds like your config file fix isnât quite right (which is not your fault). The fault lies with Valve, who have a complicated SteamVR setup which doesnât handle high res headsets very well.
I too hope that the Pimax Experience will solve this issue for Pimax users, once and for all.
@SweViver can you add me? thanks
5K+
i5 4600K
RTX 2080
16 Gb
@SweViver I have a question, for profiles, does PE will adapt profil to every pc configuration automatically ? or it will be a default profil for all ? Because i cannot have the same profil with; exemple; i9 9900k with 3080 and i5 4600 with 1080. Profil donât be the same. will PE take care of configuration to load the good profil type ? sorry for my bad english to explain this.
@SweViver Sign me up if you need more memory intensive testers 3900x, 1080TI 64GB memory and Eyetracker installed on an 8K. 8KX inbound Friday 11th.
Is this where the updates will be happening?
No, we will open the private VR Exp Beta Category for public tonight, so we can all continue discussing and reporting issues in there. Im just waiting for @Heliosurge to fix that.
The category will be available here:
https://community.openmr.ai/c/PEXPBeta/62/l/latest
@SweViver I plan on only using VR for Racing and Flight sims. The dashboard is great for all other games it seems.
From the few minutes I played in the menus, it seems like itâs just a dashboard where you can launch titles, and make your PiTool changes in, etc⌠Stuff that Simulation fans wonât really need anyway since we donât use controllers much.
I do have a few suggestions that can help us Simulation gamers though:
It would be great if it had the steamVR Settings file automatically update on launch as was promised a while back. We already have an app in the forum that can do this if you havenât seen - maybe you can incorporate it into PE?
And also for the Desktop mode, i thought it would be a flat window with the appâs settings on it, allowing us to use a mouse which doesnât seem to be the case. Itâs a mirrored window that you can use your mouse on.
Can you also make an option to allow desktop NON-VR mirrored usage of PE? And if possible, please change it from locking the mouse cursor in the window? I just alt-tab out of it, but being able to move the customer off the window without alt-tabbing off it would be a great quality-of-life improvement as well (as if itâs just a regular app window)
i have to agree that actually using the desktop view is a bit annoying because it captures the mouse and you have to place the headset to show it. I donât see me using it at all as it is.
I asked about the input field to be able execute custom script on every launch, this way we can use @BNPâs exe if it supports -y flag or similar approach.
Btw I didnât try PE Exp as had no much time recently for VR, but even if itâs no changing the file (which I believe can be a ok case) doesnât it change runtime steamvr settings which was the main goal of PE to avoid changing configs & games launched through PE will be sharp & clear coz steamvr runtime settings already were adjusted before app launch if not in config then in runtime which is safer coz config values often get ignored.
The one of the solutions atm, make a bat & do script run to adjust config automatically & then launch a steam, so every steam launch config will be updated.
@SweViver do we have a github open repo for this project? It might be much better approach to get devs and & use merge requests & forks to support such a thing, itâs way more organised & handy for progressing & onboarding new people if itâs not the case yet.
PE is supposed to implement pretty much the same functionality as my program does so if youâre using PE then you probably wont need to use my program. @SweViver can you confirm this?
