The weirdest thing is that I haven’t found any device here at home that doesn’t download these files, including 3 pcs, smartphone and 2 tablets now. IP/hostname related? maybe providing the ip address instead of artarmin.com works better?
Can anyone who has this issue, visit the artarmin website? You should see scrum poker on top of my website. Just asking.
Because if you cannot do that from either your home internet on any device, then it might be related to your ISP.
But if you can go to the correct url, from at least one of your devices, that is on the same network, then it might (and i say might) mean you have something interfering with your device that cannot open the correct url.
I think github would be a way to consistently share updates without them getting removed. I think some services like Google drive might falsely think an .exe is malicious.
Yes 87 V2 is updated. Got that version from Pimax team this morning. It fixed a few missing links with the backlight adjustment for 8KX and others.
Next official PiTool version will be based on 87 V2 and we will make sure it will include latest upcoming PE version. We know separate installers are confusing. We will soon introduce a better way of updating PE directly within PiTool and also make sure new PiTool version will always be bundled with up-to-date PE.
