The latest iterations of 7Invensun eye-tracking and UltraHaptics hand-tracking just arrived for testing.
The eye-tracking looks basically the same but now has cleaner glass edges and looks final. Also the 8KX cable is included.
The new hand-tracking module has a totally new design for the wider FOV (wider than Pimax Large FOV) thanks to new alignment of cameras, new cameras, new PCB and new housing.
Will test it the following days and report! Some quick photos below. The hand-tracking on the lower side (and closer on the first photo) is the new one.
When the magnetic inserts are removed (they also have tape, which is not necessary to use, but optional). You seen the small flaps on the removable parts? Thats the flaps that keeps the pieces in place on top of lenses. fits great. But for extra safety, you can use the tape as well).
