I posted this in another thread, but it didn’t seem to get noticed. I think this shader is awesome and others should know of it.
Through the dcs forums I been made aware of a working reshade version that works for DCS, dirt rally 2.0, elite dangerous, Iracing and assetto corsa as far as I have tested.
The files for this can be found here: https://github.com/fholger/reshade/releases/tag/openvr_alpha2
Put the files and folders into your DCS, elite dangerous, Iracing, assetto corsa, dirt rally 2.0 root install folder and for dcs put it in the bin folder. Boot up and enjoy.
Home key brings up the reshade menu. I’ve changed the sharpening to 1.500, but default is 1.000. End key turns effects on and off so you can compare.
My experience with this shader is that I don’t notice that much close up, but mid to far distances it helps very much. The sharpening is very good and from my experience it will let us lower the amount of supersampling needed while still improving the image. It also improves colors for me, but I have not tweaked in pitools. Its a cooler color scheme and it feels like it is getting rid of thin layer of fog in the image.
Please share if you find other games and simulators you get working with this.
The main Wiki as created originally by @Davebobman is editable by almost anyone. If you and others would like to help setup a more formal guide we can work together. As Reshade is a more of a general game improvement for vr we can maybe create a special guide to include Reshade and @NextGenVR’s Unity fixes.
It works great in Iracing with 8kx. See vr-forum on Iracing. You’ll need to change a setting in core.ini “connect_sockets=0” to “connect_sockets=1”. Core.ini is under documents/iracing.
Copy the files in the zip-file I linked to in the first post into your assetto corsa install folder. Start AC. Turn effect on/off with END button. HOME button to get the menu (menu only shows on monitor, not in the pimax). That’s all . It’s for play, I assume it will work for replay as well.
