New Pitool 1.0.1.197 (beta) is available now
No problems here, follow the steps as described by mReis.
@MReis thank you :hugs:. Than I will give it a try
How are you guys getting an FFR option? I don’t even have that option on mine lol
I see zero distortion on the edges so I don’t think it’s a lens issue. I think it’s shape of heads difference. It will be interesting to see if there is a solution.
I have the FFR option as always - but I do also have an 2080TI RTX Card - thats a must for FFR.
[EDIT] an RTX card
I have 120 even if I go back to older Pitools, the option is still there in all the ones I’ve tried, but the picture is ultra distorted, not usable
I’ve just tried it with Skyrim VR and it works perfectly. Even the update process works great (Just startet the .exe-file directly from the browser without uninstalling the old pitool). Great Job :+1:
Thanks for the Feedback - was the same for me - just Started the Exe, had the HMD unplugged - but worked out of the box.
This is fantastic news! Happy days. Can’t wait to get back home to test it out.
i’ve even left the heatset connected but switched off. After the installation the heatset is switched on and the firmware has been updated.
Personally, i would be keen for the option of a moving red dot like a Cylon.
Lol, I like blue the most I think
This is the update that I’m waiting for! To heck with whether the headset works, I just want that moving chevron! The Cylons are coming! The Cylons are coming!
Add me to the list of people not seeing the 120 Hz option (drivers updated, firmware updated, computer rebooted, HMD power cycled)
I have a 1080ti, is it only supported on RTX 2xxx ???
any gamma improvements for 5kXR?
BTW what happened to 180? now we have wait another half year for this beta to finish?
Same here but I have a RTX2080.
Every time I change the colour to green it switches back to blue. Its like it doesnt save the colour setting.
Do you get to work smartsmoothing with 120hz mode? Mine does not activate
I have the same problems with a 2080ti
I’m pretty sure they mentioned the 120hz is only available on the small FOV setting. I think I remember them saying that when they first told us about the new refresh rate.
