I can’t stand how dark it is. xD
Thanks at first for the new pitool version, Matthew! Is it possible to add the option “off”?
Is it odd that I’m most excited about this?
I will feedback your suggestions to the team. Thanks.
Still troubleshooting but FYI the rebooting didnt work, even did a total removal (and clearing of the pimax + pitool appdata files) and reinstallation with more reboots after that
Mmmm…no odd, people are different in excited.
I can chose the mode 120 hz and make it glow green - will test it later tonight
and FFR is also still there for me…
Edit:
Ensure it has updated the HMD and you must reboot! Might want to check your antivirus suit to off if it causes trouble ( Scan the exe before executing if unsure)
- I start up, ensure the HMD’s got NO POWER, then do the update of PiTool, reboot,
- Plug In the HMD -> Firmware is Updated, Confirm -> Reboot
- and then it all worked.
Even with fresh graphic card driver I dont have the FFR option.
Actually I dont since 180 but I though it got removed for some reasons…
Felt like it was smoother but damn it was small, it felt cramped.
Please refer to @MReis operation steps:
Thank you.
It just start and all, firmware is up to date.
There is just not the option.
Perhaps it is intentionally hidden. Do you have an RTX GPU? Those are the only ones that support FFR.
Ok I feel ridiculous on this one.
S O R R Y
So im sitting here after 15 minutes of Firmware updating looking at the progressbar @ the end and should be done. But… Nope… still says updating…
Anyone notised how long their firmwareupgrade took ?
@Matthew.Xu any things you want me to try ?
PiTool.exe CPU usage = 0%
[Edit] took a few minutes to fill the whole progress bar
mine was like 10 seconds (but I don’t have 120 Hz option)
Edit 1: @sethw how long did your firmware update take ? was is as short as mine ?
Maybe something went wrong with our firmware update.
@Matthew.Xu is it possible to roll back a firmware to try updating again ?
God. The tool still can’t be dragged. Chaotic behavior with disappearance.
Anyway, the lags and freezes are here. Still unusable.
It did take a little bit, but not long after completion the confirm dialogue/ button appeared less then a minute.
Might want to disable Anti Virus Suits if yours is known to make trouble
Seth did tge firmware update to 244? (Check pitool to verify. And to confirm you have a pimax 5k+?
Still need a fix for backlight brightness on newest pitool.
Got 120 Hz running.
Edit: moving the ufo test thing into a separate thread.
