New Pitool 1.0.1.180 is available now from Pimax
Hi,
I have the same issue with X-Plane 11 and 1.0.1.180.
Possibly with Elite too.
Price tag… and lots of videos showcsaing it’s compatibility with PiMax 4k, I thought it would also be compatible with 5k+
A lot cheaper, meanwhile it’s 3999 pounds lmao.
SFX-1000 is cheaper than this, and you won’t risk not having a product.
Is that with or without lighthouses?
Just wondering if it’s related to the internal rotational tracking or the new motion compensation…
Motion compensation is nothing that affects you unless you have a VR Motion Simulator. This is what ā€œMotion Compensationā€ is needed for:
Link to google image
I’ve seen it, but on my 8K, it goes back to 80Hz. Last night (with the .144 PiTool), several settings kept getting reset, like the Parallel Projection option.
I’ve looked at that one before. It looks like it would work very nicely with Elite Dangerous, but unfortunately, I don’t have the space for something like that.
indeed. space is not great with it! Unless you get creative and find a way of storing it out the way or outside lol :wink:
Hi,
I use one htc lighthouse only. No controllers since I fly using my yoke/joystick and pedals.
There is no problem when flying with the Condor 2 glider simulator. Maybe this has something to do with parallel projection? Condor 2 does not need it, while X-Plane 11 does.
Have the same problem with .144 Pitool - refresh rate and PP or per game settings are resetting every restart, I thought this may be something to do with the permissions on the Pitool files, but then realised that FFR settings stay.
I’ll check .180 later today.
Motion compensation is used for motion platforms with LH tracking to allow rig to move without affecting tracking from my understanding.
There is a complete thread on motion compensation.
And here’s a link to that thread…
https://community.openmr.ai/t/is-motion-compensation-working-with-pimax-yes-use-pitool-180/14634?u=neal_white_iii
I’ll check on project cars in a sec and see how it goes.
Also guys for XR oled owners…
The black level setting is in here too. Yay!
I tried pcars with parallĆØle projection and then without it. In both cases, it doesn’t look like an improvement. Please share your feeling about it.
Currently fixing up Pitool downloads. Is black level adjustment only present in 5kXR?
But that SFX-1000 seems to be an ordinary four actuators racing sim motion rig ? If racing sim is the only sim you want to play it may be a reasonable alternative but not if you are interested in flight sims, is it?
But at this stage of the project I would indeed wait for the FeelThree to be completed and delivered to the backers - when their feedback is positive, youā€˜ll surely be able to jump in at a cost tag not much higher than the current one, knowing it’s proven hardware.
If it should work out as advertised, I expect it to be a great motion rig though.
Are there beta install instructions? Specifically, I am running current RC PiTool, thus do I need to uninstall that first and then install beta, or can i simply install beta and it will overwrite automatically the RC. I see the installer does not allow you to choose where to install. please advise. thx!
Any chance of the XR true black fix!?!?
Edit: Heck yeah I see the option, its testing time!
