Update Index controller compatibility and this includes updates for the use of Index controllers with some gaming titles.
Update Oculus Software support.
Improvements:
Bug fixes and optimizations to the PiTool UI.
Optimize the usage rate of GPU, which will improve the performance. There were situations where the GPU would not be fully utilized and this fix should allow the GPU to be fully utilized.
UI now asks you to identify your controller when you attempt to pair them. This allows for further optimization for the pairing process.
Fixed a bug where there was a small possibility that the headset would not properly initialize. When this would occur the screens would not properly start and the headset red light would appear.
I’m particularly interested in these two items. Improved performance is always good and I experienced the black screen issue earlier tonight.
@anon74848233, I also ran into an annoyance: The Parallel Projection option turned itself off SEVERAL TIMES, while tweaking settings like refresh rate and vertical offset. The UI showed it as enabled, but I saw double images in Elite Dangerous and when I restarted PiTool, the option was shown as disabled.
Is this on your list of defects which need to be fixed?
Is it possible for PiTool to have a display mirror option like steamVR has. So if I launch a game from PiTool I can see a display mirror? Currently this is not possible it would be nice to have this feature I think.
Some games run much better if you launch them from PiTool directly and bypass SteamVR
If this GPU usage fix does what I hope it does (basically apply the workaround) then I am a very happy user.
I wasn’t all that happy that the 5K+ needs its own software to run and hoped for SteamVr only. I am positively surprised what the Pimax team pulls off with PiTool though. It ain’t perfect but we keep getting new options and optimisations. Nicely done Pimax.
