I bought a new Pimax 4k + nolo, trying to get it to work now.
Situation:
Using Windows 7 with GTX970
I’ve never seen any display in the headset using Pimax mode. I have seen a desktop display in video mode. The LED on the headset is usually blue.
Headset seems to have the most recent firmware.
I’ve installed Piplay from the website, so I assume its the most recent version.
I also installed Pitools from the same place, I assume its the most recent version.
Nolo parts are all paired.
On room setup, I see the 2 controllers and the device that sits on the headset as connected. The 4th one, the “lighthouse”, is not connected.
I’ve followed a lot of searched solutions, tried reinstallation, stopping & starting the PiServiceLauncher etc, nothing has changed. Yesterday, once, I saw all 4 devices as connected, so I know it can be done. I have no idea what caused that to happen though, and it didn’t last long.
So in summary I seem to have 2 problems:
No display in Pimax mode.
No tracking.
I have ~10 days to solve this before I return it under Czech consumer rights, so fingers crossed.
Kindest regards
DMarkwick
*edit
Something I forgot to add:
Another detail: I often see references to a “enable lighthouse” option in Pitools, but I never see it. Also, in my C:\Users\username\AppData\Local\Pimax\runtime folder I don’t see any config folder, so no config/lighthouse files to delete, which is something I often see as part of a solution.
