since I have all the VR headsets that are currently on the market (and a few that aren’t) I thought I should finally do a big FOV comparison, simply measuring them all! Lots of FOV specs provided by the manufacturers are simply wrong. For the measurements I used the ROV TestHMD environment.
Since I do not wanna force you to watch my video, let’s directly do this here:
Oculus Rift S 86°/110° (horizontal/vertical)
Vive Cosmos 82°/112°
HP Reverb G2 98°/114°
HP Reverb G1 94°/106°
HTC Vive Pro 98°/126°
Valve Index Max 108°/130°
Valve Index Min 100°/112°
Odyssey+ 102°/130°
Oculus Quest 92°/116°
Pimax Artisan 128°/124°
Pimax 8KX 140°/124°
For the Valve Index, I have measured it with lenses as close to eyes as possible (MAX) and as far away as possible (MIN). Pimax headsets have been set to their respective maximum FOV setting.
I hope this is useful for you. If you want to support the channel and learn about my take on these values, please watch my video:
Most of those vertical FOV look too high too, I’m no expert but it feels like something has gone wrong here since some are showing higher than what is actually rendered. Is it possible that tool is not rendering correctly now?
Relax, we have some blokes who already have an 8KX. Let them do a measurement of the 8KX and another of the listed headsets to check which values they‘ll come up with.
Just tried ROV TestHMD with my 8kX. Getting pretty much exactly 140° with normal and 160° with large FoV.
For vertical it was a bit more difficult as the upper marker went out of view faster than the lower marker. The upper was at a little above 100°, the lower about 120°.
