So yesterday my 8K X has arrived - silently.
I guess most is known, and well Pictures say more than words, so I’ll keep it short.
The 8K X Improves on every aspect - period.
The Image supersedes the 8K+ even if I reduce from 1.5 or 1.25 to 1.0 in the 8K X. Its sharp like a monitor to me in most cases. Racing is beautiful (Dirt 2.0, Asseto Corsa competizione)
Packaging is very nice, and the Head Strap is quite usable - its comfortable - I would have liked just a few adjustment possibility’s more - but its good none the less.
The 8K XY is the BEST, no points in arguing - I would say get the Artisan if you don’t want to burn so much money or save up for the X - period.
Funnily I ran the 8K X just using USB 3.0 and no power on the 2.0 (I forgot to power on the plug strip) and it ran… will try again tonight WITH both powered up
Hi and thx for your short review! Feel free to post more of your impressions along the way
Original 8kX backer or upgrader? If upgrader, when ordered and approx. order number? thx and viel spass !
Why they do not take time to get simple stuff as text in correct english
For the love of… their American COO is located in Florida, and is borne and probably raise in the USA.
sorry for the thread hijack MReis
I do like that Pimax have listened ! For example they now protect the lenses when they ship the hmd .
For the future I would love to see a prebuild deluxe audiostrap , eye tracking PRE BUILD and TESTED .
and ofc a thin face foam included in the box
Its good - it sits nicely and can be easily adjusted.
Its not the perfect solution - I would have liked to put down the part that connects to the hinges more (or better put tilt the HMD further downward, so I could get that neck cushion deeper - but since the HMD wont tilt down more, the HMD is lifted a bit too much away from my checks.
But since it sits nicely, Its not really an issue to complain - Head Strap 2.0 maybe
Thanks, I do - just keep driving one Stage after the other in Dirt 2.0 - looks very very good - truly I would say better in VR now then on my WHQD Monitor - just drove in Sweden - the melting snow is awesome on the windshield in VR 3D!
(I wanted to try DCS, but it has some steam issue, need to check it but wanted to just use the HMD).
Yeah I got the meaning of the saying - but its a bit of english (even for my expertise in writing). But that is not a pimax issue - I dont remeber, but its very often now days that you get a bit of translations - I guess the languages are just to diffrent - but Kevin could have checked it
I check a lot of them, some make it in quickly, some changes take time. Sometimes it’s thought the wording is ok when it still needs a bit of tweaking. We’ll get more and more of the text updates in there.
