3am for me
I gotta go sleep 11pm and wake up at 2:30am.
12 hours from now. Lets pray this goes well.
I’m assuming that’s just a figure of speech. I understand your motivation and I certainly hope that the event goes well, but personally, I won’t be praying for something so materialistic. So that we’re clear, my statement is not intended to be a holier-than-thou comment, just that in the scheme of things, this is only a minor event, not a life-changing one. (At least for us; it might be for people at Pimax.)
I also wanted to buy a Pimax 8kX.
However, I can only advise against so far.
Pimax apparently did not solve the case problems until today.
Apparently, nothing is done against it.
I received my Fifth or Sixth Pimax 4 days ago.
After 2 days again cracks!
It is cruel!
I am also so angry.
I’m starting to feel like it.
I also can not believe that there are housings that do not break.
Always cracks. It never ends.
Instead of solving the problem, Pimax is building new VR goggles with the old scrap case.
I am so angry and disappointed.
I can only advise against buying a pimax goggle.
You obviously get all VR glasses with cracks.
It’s terrible!!!
Pimax should finally solve the problem!
You seem to ignore it.
Contact @Matthew.Xu @SweViver @PimaxUSA. If this is really your 5th RMA they need to sort it out.
Sorry for my mistake, I’ve modified the time.
Hopefully someone can settle @Timo.H1’s issues with his headset.
I have been paying attention to your situation. I told you that if you have any questions, please contact me.
Please don’t be angry. I wonder why only the headset you received keeps cracking.
Let me think a way to help you solve your problem.
If it’s convenient for you, we’ll go to the helpdesk.
Official Pimax comments on the issue of cracked housing, improved manufacturing and calibration process, improved quality assurance testing phase and improved RMA process
Answer to the question: What calibration?
After late August internal device manufacturing process was improved. As for the improved housing, models containing improved housing reportedly started shipping on the 1st September or September 16th, having regard to the below two posts:
This was over a month ago, are RMAs still not coming from the Shanghai office? @PimaxUSA Why is this still happening when @Timo.H1 's above RMA request has been made after 16th September? Economy shipping takes 2-4 weeks from China to the US, and 28 days before the 25th of October is the 28th of September.
16th September-25th October is 6 weeks after the date given for RMA of new casing improvements would occur on the 16th September.
45 days ago is enough time to ship a headset and return it from Shanghai isn’t it? Can this be clarified and will Pimax indicate the status of stocking other warehouses besides the Shanghai office with the models containing improved housing and calibration referred to above?
Doesn’t sounds right, 8KX has nearly twice combined horizontal pixels compared to Reverb (7680x2160 vs 4320x2160) so even at 170’ large FOV the pixel per degree (PPD) on the 8KX should be a little higher than the one on the Reverb, around 45,1 vs 43,2 PPD.
Moreover Reverb has a horizontal wide pixel arrangement, as Sweviver has shown with his macro shots, making the Reverb horizontal resolution a less optimal way for displaying fine details considering its very narrow, almost squared size horizontal FOV.
So both image resolution and SDE are definitely going to be better on the 8KX, regardless of the wide FOV.
We’ll see for ourselves anyways once the 8KX reaches the hands of backers.
The delivery of my new Pimax 5k + has been shipped directly from China.
It only took 7 days with UPS to Germany.
The shipping was very fast.
I assume it was the current model. It has been sent directly by Pimax.
This sounds like poor plastics design where stresses are built in or there are stress concentrations during assembly causing the cracks. I’ve not had any issues however with my 8K.
I’ve been designing plastic mouldings for nearly 30 years so if you want to send me a set of case parts I would be happy to have a look at them for you.
Yes, sharp corners and joints are not as strong. There’s a reason why the windows in airplanes have rounded corners.
Everything was ok on the first day.
On the second day, a crack was created in the middle of the housing. On the 3rd day the crack has got bigger. On the 4th day (today) I have not looked.
In what State Dir your Package arrive? Mine was a bit beaten up. I wonder what stress the HMDs are going through, at least the big one seams like there is either pressure on it structure vice or it got an impact. The smaller looks classical like the bridle plastic issue …
I wonder if you can put your problem in the post of housing reports, which is not suitable for discussion here.
https://community.openmr.ai/t/housing-issue-reports-cracks-imperfections-etc/17203/765
I understand your mood. I’m trying to help you.
I suggest you don’t have to be so anxious…Thank you.
4 posts were merged into an existing topic: Housing Issue Reports (cracks, imperfections etc.)
