Been trying IPD settings for 30 mins and reading ED text, just not right. Always blurry in one eye, until I turn my head. Looking straight at text can’t be clear in both eyes. Had to take a break it was too uncomfortable, plus the weight of the thing is significantly more than the 5k+. No wonder they refused to disclose the weight in advance when asked.
5k+ may not have been perfectly set up, but was acceptable. Minimum mechanical IPD and offset of -1.5 was OK.
I guess mechanical minimum must stay the same. I think I need to have somewhere between -1.5 and 1.5 of offset on the 8KX, any extremes and it feels really wrong.
Reading this: https://community.openmr.ai/t/how-to-make-your-pimax-image-picture-screen-clear-crisp-increase-clarity/29688
But no joy. I changed the default image to the IPD one, I find I can never get the text clear and crisp, is it possible? Changing settings makes them illegible.
I see a bit of curved distortion too, which I never had on the 5k+. I am currently using a thicker VRMust foam because the supplied thin one was instantly and obviously unusable to me. But perhaps the VRMust foam isn’t enough either? I might try to velcro both together and see how that goes…
