My IPD is 69.5.
Upgraded to latest firmware *.176 yesterday on both 8K and 5K+ and maybe its placebo effect only but I find the distortion to be even less apparent in the edges now than before with *.146 firmware.
But yes there is some apparent blur in the edges while using Large FOV, slightly less when using Normal FOV though.
The last 5 maybe 10 degrees on each side feels a bit distorted and blurred but that has always been the case (as i mentioned it in full review) but probably i have just been used to it and it really doesn’t distract me. While in game I hardly notice it at all.
What I dont see is any distortion in the center 120-130 degrees. The binocular overlap outer edges gives a slight blurrier overlap as mentioned before, but i wouldn’t call it distortion. I think this has been improved since early days of PiTool and firmware.
I must add though, that if I use an IPD of 67 or lower I get a little bit strange and dostorted image even in the center or within the center 100 degrees. A little crossed eye effect as well. This is why I always point out to check your correct IPD and not just guess.
Also move around the headset to really find the sweetspot for wearing. While the visual sweetspot area (sharp area) ia huge on Pimax, its still easy to wear the headset wrong (too low or too high up) which dramatically changes the visual result. The better audio strap will hopefully make it easier to wear the Pimax in the end.
During m1 beta the center distortion was a big problem for all of us testers, especially in a few early iterations of PiTool. We could see blurry spots, geometrical distirtion, sometimes wrong scale (things too big or small) and so on. But luckily, ever since before the Berlin meetup, all those issues were fixed.
Today if i compare my Odyssey to the 5K or 8K, I find the edge blur on my Odyssey worse than on Pimax. On top of that my Odyssey always gave me a slight pupil swim effect which I never really got used to…
I find all these different opinions about Pimax distortion so difficult to understand, but I totally get it, we are all different. Some people see slight distortion, some doesn’t see it at all (!!), while some can’t handle it and says its extreme.
I guess we will need eye tracking to make it perfect for everyone…
