Edit:
TLDR: you can do this with DiRT Rally too, but recentering the headset doesnât center vertically, and because of this you have to set your Pitool room setup distance to floor to around 150cm (while wearing your headset at your seat and keeping your head still). Anyone know how to fix it to recenter both ways?
Woah. I saw your DiRT Rally video too, but I wasnât sure if PP was needed or not, and it also seems like it doesnât need parallel projections either??? I used to try running this through Pitool, but with SteamVR running. I guess the key is just do not run SteamVR. My only issue is that I canât recenter my headset, Iâm 5 feet above the roof. It recenters, but only above the wheel. Any idea how to fix that?
I sort of figured it out. You have to put the headset distance from floor to your head, while wearing it and sitting in the room setup. So:
Do the Room Setup in Pitool, but make sure to:
- âCenterâ the headset around where youâll be sitting with it on.
- Wear the headset and sit still, while putting ~150cm in the box. I did 137 and it wasnât enough, so 150 should be about head height.
Doing a recenter doesnât change the vertical distance, just horizontal for some reason. If anyone else can figure out a better way, let me know.
There is no problem if you donât use a light house. I have not tried the light house yet.
Awesome @park
So you need pp or nah?
Park if you find out how to play echo arena without PP Iâll pay you $20 I swear (lone echo doesnât require PP just so you know)
Also Skyrim VR without PP would be pretty gangnam style
I tried doing this with PC2, but sadly it didnât work
I then thought about how much the image is offset when adjusting the software IPD(and put it at -10), and this actually put the âcockpitâ mostly in focus.
I tested it with pcars2 demo and it works fine.
Are you just creating a new text document, or are you right clicking the PhysX3Gpu file?
Did you try âreset seated positionâ in the âpower buttonâ menu?
When I launch from PiTool, I canât do a reset using the controller, it wonât bring up that steamVR menu because SteamVR isnât on. If SteamVR is used, then Iâd need parallel projections on.
Maybe thatâs why I canât get it working with PC2? SteamVR launches when I open the game from Pitool.
same hereâŚ
Can you please write a step by step on how to do this, I do not understand what you do in the movie. (Chines letters or something). Does it have an impact on roomsetup? I use Vive lighthouse.
Wait so you could actually play games that require PP if you put software IPD to -10� Could you play PC2 after you did that�
1.Create âsteam_appid.txtâ in the folder where pcars is installed and write 234630 in that file.
2.If oculus home is not installed, copying both files LibOVRRT32_1.dll and LibOVRRT64_1.dll(https://drive.google.com/open?id=1M11Zdytb_B3_r5v2oI5pr7ZCTKxdnam1 ) to the folder where pcars is installed
No, I donât think the images would completely converge(some parts would be aligned while objects in the distance wouldnât). I would like to see how it would look if we could push it even further(maxing to -10 aligns some of the image). I have found the Pitool config file, and Iâm tempted to edit a lower value, but Iâm not sure it would allow it.
