Finally I received PIMAX VISION 8KX today [Review]
I’m one of the 8KX Backer from Japan.
I was just an PIMAX4K user until now.
Today I received PIMAX VISION 8KX and play AutoMobilista2 on VR.
First impression is very good.
Easy to set up, Easy to use.
There is no screen door effect.:slight_smile:
The display brightness dynamic range is bit narrow.
I adjusted the contrast and brightness settings on Pitool, but that wasn’t enough.
I think it is necessary to control about the gamma curve.
I don’t know if it is possible or not.
No drawing delay and so Smooth. It is very good frame rate on my Geforce 1070Ti GPU.
No lens distortion.
There is chromatic aberration.I don’t care about it.
The IPD adjustment is so easy. nice.
IPD setting was weird when I used the PIMAX 4K.
but this time it’s perfect.
SMAS is just convenient to use.
The volume is set to maximum, but I felt the sound was a little low.
The volume cannot be raised anymore.
I tried to add a USB amplifier, but the left and right cables are too short, Connection is a bit difficult for me.
I would normally use my headphones.
If you want to use headphones, you should select SMAS model not a DMAS.
I don’t have a base station so I can’t setup 6dof tracking.
The gyro is stable. no problem. nice.
I hope to see the reviews of other 8KX users.
SEND PICS NOW.
Show it!
Also I highly recommend you get base stations.
@coverman what was your backer no.?
Congrats! Have added you to Earlybackers Group.
Did you have issues with Distortion on the 5k/8k headset?
Congrats! If you are not waiting for basestations and controllers from Pimax then best order basestations and optimally Index controllers asap (best directly at Valve) to place yourself in the queue, it can take months until they arrive. Almost as expensive as the 8kX pledge, I know, but imho worth it!
Or, if you are lucky you can get a cheap used gen1 Vive bundle somewhere. The Index controllers are a lot better than the wands, but if the price it right this might still be worth consideration (particularly if you are a sim fan and the controllers aren’t as important for you - but 6dof is definitely adding a lot to the experience!).
Fantastic thank u for posting. It’s started!!! :clap::partying_face::exploding_head:
Congratulations, hopefully many more will follow in short order :100:
I’m 8KX Full Backer #143
So I was supposed to receive Basestation (x2) and Controller (x2) at the same time.
I want to get 6dof as fast as I can.
CONGRATULATIONS
did you have tracking ?
What is your Cpu ?
What is Your Pitool setting for automibilista ?
What is the steam setting you are using ?
What is the resolution in steam
Sorry, these are many questions…
Congrats! :blush: One Base is enought for Sims. The fastest way is ebay. There are some sellers from China. Sell it as used, but the items are new.
That was fast and congratulations!
You should ask your wife to try it!!!
What is the FOV …?
Have you tried the Valve Index or the Pimax 5K+? If so, how do the colors, contrast, brightness and black levels compare against those two HMDs?
I didn’t rent 5k/8k form pimax team.
So i don’t know about 5k /8k.
In my opinion, lens distortion is as small as nothing.
I do not care about distortion at all.
Thank you for your suggestion.
The valve index is out of stock and not readily available, so I wait for information from PIMAX.
If you backed the full package you can create a ticket with pimax to send you the base stations now. Also, there may still be the option to pay extra and get the Index controllers instead of Pimax so you get them now as well.
Same as the 8k+ as same screens. Against 5k+ better blacks, colours are not as good.
no toracker. PIMAX inside gyro only.
CPU:core i7-3930k 3.2GHz
memory: 16GB DDR3
PITool: render quality is 0.75 :wink:
steam setting is 1.0 not use supersampling.
automobilista2 render seting is high.
I’m waiting to release geforce 30xx, then I’ll buy a new PC.
Congrats that you received your 8KX, have fun with it.
I am the same for me Distortion in the 5k/8k is minimal for me that it does not cause me any problems enjoying the headsets.
